Problem with HF wheel dust caps
Postby SmokeyBob » Tue Sep 06, 2005 8:28 pm
Today I tried to install the dust caps on the wheels. One side is so tight I can't get it all the way on. The other side is so loose I can pull it off with my hand.
I might try switching them tomorrow. :thinking:
Anyone else have problems like this with their HF trailer's?
http://www.mikenchell.com/forums/album_personal.php?user_id=1169
Pics for Building the Alegria I
To view video click Here
Bob & Judith
SmokeyBob
Images: 161
Postby madjack » Tue Sep 06, 2005 9:39 pm
...as any old timer on this board knows...the answer is yes :D
After you have tried swapping and if still the same, cut, preferably with shears or snips a couple or 3 or 4 slots around the very edge of the too tight one and take a hammer, preferably a ball peen and "peen" the very edge of the loose one from inside out. Dust caps on HF trailers have been a problem for many
Postby lmh222 » Tue Sep 06, 2005 10:23 pm
Yup, I've lost a few (I own two HF trailers). The bad news is that they are a really weird size that I couldn't find in any parts store. The good news though is that you can call HF and order more. They're only about $1 each plus a few bucks for shipping. I ordered 5 just in case.
I have found that silicon adhesive works well for a loose fit. I only put a few dabs right on the outter edge. It peels off easily too. Of course duct tape works too but it is a bit ugly.
I use a rubber mallet to tap on the tight one.
Good luck.
~Lindsey
The difference between being involved and being commited is like eggs and bacon - the chicken was involved but the pig was commited.
http://www.teardrop.myphotoalbum.com
lmh222
Postby madjack » Tue Sep 06, 2005 10:39 pm
...Bob I would also HIGHLY recommend that you pull the hub and insure the bearings are properly greased and tightened...a little hassle now = no headaches down the road
Postby SmokeyBob » Wed Sep 07, 2005 11:24 pm
The first thing I did was check the bearings for grease. They looked OK but I added some more just to be on the safe side.
Switching the dust caps worked for one. The other one was still loose. Your suggestion to use a ball peen hammer got me to thinking. I took a spring loaded center punch and went around the inside lip of the dust cap making little dimples. It seamed to work, I coludn't pull the cap off with my hand.
Time will tell if it stays on. Thanks for your help. :applause:
Imh222
That's a great idea about getting extra caps. Looks like this could be an on going problem.
Check out my album if you want to see a low tech tool for installing dust caps. Got the idea while taking Auto Mechanics many years ago.
Hopefully this link will work
Bob & Judith
SmokeyBob
Images: 161
Users browsing this forum: Bing [Bot] and 3 guests
