halfdome, Danny wrote:I use a rabbet bit to cut the profile down to accommodate the weather strip after the roof plywood is on.
They sell rabbet bit kits with different sized bearings for different rabbet sizes.
From the outside I route only half way in and then finish it up with a straight flush trim bit with a top bearing riding on the previous cut.
Nice and easy and it keeps your profile to weather strip tolerances perfect.
Javanino wrote:halfdome, Danny wrote:I use a rabbet bit to cut the profile down to accommodate the weather strip after the roof plywood is on.
I think I'm with you. If you put a rabbet on the outside of the profile plywood and attach the weatherstrip to that and leave the inside part of the profile high, it would make it nearly impossible for water to run into the galley. Great idea!
Next problem is the hinge. I really don't like the idea of a hurricane hinge sticking out an inch on each side. Looks like something to remove a little flesh when you least expect it. Not to mention it's ugly. There's got to be a better way. Maybe this rabbet method would make the 1 inch hangover unnecessary.
grant whipp wrote:Lots of folks have differing ideas, but in my experience, a 1" overhang of the Galley Lid Hinge is unnecessary ... I only recommend 3/8" on each side, just enough to guide the water off the top and away from the Roof Edge Moldings and the hinge gap (I also sometimes run a piece of Door Seal between the hinge pieces, sealing that gap ... not totally necessary, but it really helps on dusty roads!). However you choose to go about it, Good Luck!
And, oh, BTW ... I recommend a 1/4" step-down (or notch) in the profile aft of the body-side hinge beam ... but again, others will differ.
CHEERS!
aggie79 wrote:I can't remember who - I believe it was Danny (above) - was gracious enough to explain to me how to cut the "notch" for the hatch after the sidewalls are up. Here are a couple of sketches and pictures that show that process using the router and bits Danny described. (Click the images for a larger view.)
