Endo wrote:Use some oil on your drill bit, it should also make the drilling much easier.
Steve Frederick wrote:WD-40
m&devans wrote:Hi,
use a high speed drill or a titanium coated drill, carbide drills are designed for concrete not steel
Nitetimes wrote:You could also use these fasteners to bolt the deck to the frame, they are what I am using. One man operation and very effective.
bottom of page on left
Also no bolts and nuts hangin out the bottom to snag things and rust.
JunkMan wrote:
Those are nice, I might have to try to find some locally for my floor. Too bad they don't come shorter than 1 1/2", 3/4" or 1" would be plenty to fasten 1/2" plywood.
