Harbor Freight Stamping Set: Product review
Postby StPatron » Sat Apr 07, 2012 11:49 pm
My trailer registration process required that I stamp the state issued VIN numbers onto the frame. I was a bit leery of the results I would obtain using the Harbor Freight stamping set but for a bit over 6 bucks w/coupon decided I'd give it a try.
I used a hand-held sledge hammer and gave each stamp 6 solid hits. I was pleased with the results.
If you're needing to stamp numbers or letters onto steel, this set will do the job.
(The angle of the lighting tricks the eye, the stampings appear raised. They're not, they're stamped into the metal.)
90467
90468
StPatron
Images: 297
Re: Harbor Freight Stamping Set: Product review
Postby StanDahl » Sun Apr 08, 2012 12:20 am
That's a more comprehensive test than I've done. I bought a set of those and have so far only used them to stamp lead ingots.
It's not as hard as a trailer frame, but they do just fine on lead too, in case anyone wonders.
John
StanDahl
Postby PanelDeland » Thu Apr 12, 2012 9:16 pm
I used them to number main and rod caps for a Cheby.They worked well in cast iron.
"I know the voices in my head aren't real,but they have some really good Ideas!"
PanelDeland
Postby absolutsnwbrdr » Fri Apr 13, 2012 7:53 am
StPatron wrote:(The angle of the lighting tricks the eye, the stampings appear raised. They're not, they're stamped into the metal.)
90467
90468
Thats a pretty good optical illusion you've shown us. :thinking:
Looks like the stamps worked really well.
Zach
Coming Soon...
absolutsnwbrdr
Images: 412
90467
Thats a pretty good optical illusion you've shown us. Are you SURE those are stamped in?!?! :thinking:
Looks like the stamps worked really well. :beer:
Zach
Coming Soon...
absolutsnwbrdr
Images: 412
Postby StPatron » Fri Apr 13, 2012 11:30 am
absolutsnwbrdr wrote: Thats a pretty good optical illusion you've shown us. Are you SURE those are stamped in?!?! :thinking:
Ok... I'll fess up. The amazing thing about the stamp set is that you just hold the stamp over the metal, then say the magic words and... wallah! Raised lettering! Cool, huh? I think they're magnetic or something.
StPatron
Images: 297
Postby KCStudly » Fri Apr 13, 2012 12:37 pm
Pssst, pssst...hey over here. The magic word is, "Whack"!!!
Postby jason_boivin » Fri Apr 13, 2012 7:12 pm
KCStudly wrote:Pssst, pssst...hey over here. The magic word is, "Whack"!!!
With a BFH.
jason_boivin
Postby KCStudly » Fri Apr 13, 2012 7:59 pm
Did I see it here?
"When the only tool you have/own is a hammer, all of your problems begin to look like nails."
Postby logman7777 » Thu Apr 26, 2012 9:57 am
+1 for the HF set..I use it 5-10x daily to mark serial ##'s on thick Stainless Steel equipment tags Over 1 year of constant use and no signs of wear.
Coleman Keepers 200A Gang
High Wide and Handsome Probationary Member
Happy Camping!! -Andy
logman7777
Postby Steve_Cox » Fri Apr 27, 2012 11:55 pm
I've got one of those HF Stamp sets, I use 3/4" X 1/8" aluminum flat stock and pop rivet my VIN number tags onto the trailer tongues. Never know when you might want to change one.. 8)
Steve_Cox
Images: 196
Postby eamarquardt » Sat Apr 28, 2012 9:27 am
Steve_Cox wrote:I've got one of those HF Stamp sets, I use 3/4" X 1/8" aluminum flat stock and pop rivet my VIN number tags onto the trailer tongues. Never know when you might want to change one.. 8)
Yes, officer, I'm sure that is the correct tag for this trailer and that all of the registration fees for this trailer have been paid. That's my story and I'm sticking to it officer.
Gu
eamarquardt
Images: 150
