pohukai wrote:I just started building this last weekend and realized one unspoken fact; If you're working alone, these materials can be heavy and/or bulky making it very difficult to complete your build.
Granted, my TD floor is similar to the XII (2x4) and I found it very difficult to move the frame into position by myself even without the 3/4 flooring. With that foresight, I'll build a block and tackle system to assist me with the lifting/positioning and securing the walls.
I'm trying to think of what other unplanned sub-projects I'm going to need to do.
Jim
Jim, I built my TTT by myself; so, from memory, I can say when I asked for help from a friend or neighbor:
1) Turning the metal chassis over after it was built (for safety reasons)
2) Holding the wall in place and upright until a couple screws were installed to hold it
3) Lifting the pre-constructed, pre-painted roof into place without scraping the paint. (You'll probably build your roof in place.)
4) When I thought I might injure myself if I tried lifting the fallen tongue while alone. (OOPs! You probably won't do
that!)
5) Final inspection by an experienced person (You probably won't need this one either....I just felt better doing this.)
6) Also, had I known better, I would have asked for a second set of hands when I was trying to skin the front curve. That was awkward...did it alone with lots of sweat & "words".
Tipping things up on end works pretty well. Pivoting can also be helpful. In many situations, leverage is your friend.
Knock on wood, I never dropped anything except the tongue (and that scared the H--- out of me!).
