Questions re mounting a Fantastic Vent on a curved roof???
Postby cracker39 » Mon Sep 12, 2005 2:08 pm
There may be some info on this in the posts somewhere, but that's a lot of posts to go through to find it, so I'm asking here. If you have a link to your build info with the answer, please reply.
Will the Fantastic vent mount on the curved roofline of a TD without some sort of filling in? Does a flat wood mount have to be fitted into the roof framing, extending above the curved roof? Or, will weatherstripping fill the gap adequately? Thanks.
Dale
cracker39
Images: 233
Postby IraRat » Mon Sep 12, 2005 2:51 pm
Dale, 99% of TD designs have you more or less flat on SOME section of the roof. The vent is only around 14" square, and if you look at most profiles, it's not a problem. Also, the flange on the vent is very pliable, molding to the roof curve as you tighten its MANY screws.
But you're gonna seal well anyway, right? I used 3M's 5200 marine sealer. Goop in a tube.
--Ira
IraRat
Forum Storyteller
Postby cracker39 » Mon Sep 12, 2005 4:29 pm
Definitely gonna seal it well. If necessary, I can use my band saw to make an "adapter" frame. I thought about making sure that the upper part of my roof sort of flattened out for the fan mounting, but I hate to spoil a nice curve. True, the curve will flatten out a lot after the first 12-16 inches from the front, so it may not be a problem. I'll have to get the fan and check it before I start. I do plan on getting all of my parts before building anyway. I want to be able to put everything on the completed chassis: floor, sides, parts (AC, fan, mattress pieces, battery,etc.), other wood materials, etc. so I can "balance" the chassis for the correct tongue weight and exact axle placement. Then, I can put on the axle and move the trailer chassis to my build area. My wife won't let me keep the carport to use for assembly as her car would have to sit outside (poor car). I did convince her I needed the flat concrete floor for welding up the chassis and assembling the sides.
Dale
cracker39
Images: 233
Postby Arne » Mon Sep 12, 2005 4:44 pm
When I am faced with similar situations, I try to make the surface as friendly as possible, I build a frame, or a filler. I wouldn't try to bend the bezel too much, as with sun, etc., down the road, it may crack.
I'd mount the fantastic fan flat to the surface on the front (hinge side) and build it up towards the rear.
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
Postby Ken A Hood » Mon Sep 12, 2005 4:58 pm
http://members.aol.com/fantasticvent/im ... mbezel.jpg
This is for an airstream, which curves side to side; but you could turn it 90 degrees and have it run front to back.
Ken A Hood
Images: 42
Postby cracker39 » Mon Sep 12, 2005 5:32 pm
That would work on the inside, and that's not what I was concerned about. I won't really worry about it until I get my fan and start to mock up my template. It may not be as much a problem as I'm imagining it to be.
Dale
cracker39
Images: 233
Postby Denny Unfried » Mon Sep 12, 2005 7:32 pm
Here are a couple photos from my web site how I made a 16" flat on mine for a vent. The extra wood around the hole is for the vent to screw into.
Denny
aka - "Uncle Denny"
<img src="http://www.uncledennyscorner.com/teardrop/photos/Linux.gif">
Denny Unfried
sprint car builder/racer & all that jazz
Postby cracker39 » Mon Sep 12, 2005 8:15 pm
Thanks, Denny,
That is one of the ways I had envisioned it looking. Another is to keep the curve and raise the square frame for the fan slightly above the curve. I'll have to think about which way I want to do it. No matter how much I plan and make diagrams, when it comes down to it, I make final decisions when I actually get down to the construction.
Dale
cracker39
Images: 233
Postby DoWopBox » Mon Sep 12, 2005 11:49 pm
Denny Unfried wrote:Here are a couple photos from my web site how I made a 16" flat on mine for a vent. The extra wood around the hole is for the vent to screw into.
I am getting ready to frame mine up. What size is the hole for the Fantastic Fan? I want to set mine up like you did. Can't afford to buy the fan yet.
Aerodynamics is overated
DoWopBox
Postby bledsoe3 » Tue Sep 13, 2005 12:48 am
I have not purchased mine yet, but I'm told the opening has to be 14 1/4 X 14 1/4. I also read that you'll need extra framing on the outside for the trim ring to screw into. Again, all this info I've got from this forum. So it must be correct. At least I hope so cause that's how I did it. :worship: Jim
bledsoe3
Images: 112
Postby IraRat » Tue Sep 13, 2005 8:53 am
bledsoe3 wrote:I have not purchased mine yet, but I'm told the opening has to be 14 1/4 X 14 1/4. I also read that you'll need extra framing on the outside for the trim ring to screw into. Again, all this info I've got from this forum. So it must be correct. At least I hope so cause that's how I did it. :worship: Jim
You're cool.
--Ira
IraRat
Forum Storyteller
Postby bledsoe3 » Tue Sep 13, 2005 9:34 am
IraRat wrote:You're cool.
You're just saying that cause it was you who mentioned the extra framing for the trim to screw into. :lol:
bledsoe3
Images: 112
Postby mikeschn » Tue Sep 13, 2005 9:46 am
Yes, the rough opening should be 14 1/4" square, and the vent was designed to fit into 2x2 framing. I too posted something about that a long time ago. Good to hear people are reading that stuff and remembering! :lol:
Postby IraRat » Tue Sep 13, 2005 10:17 am
bledsoe3 wrote:You're just saying that cause it was you who mentioned the extra framing for the trim to screw into. :lol:
If I learned anything here, it's that 14 1/4" dimension.
By the way--my cheap $15 Elixir vent (no fan) fits into that same opening.
--Ira
IraRat
Forum Storyteller
Postby DoWopBox » Tue Sep 13, 2005 10:42 am
Good to know about the cheaper vent. Now I'll have a temporary hole-plug. :thumbsup:
DoWopBox
