Denny Unfried wrote:Here are a couple photos from my web site how I made a 16" flat on mine for a vent. The extra wood around the hole is for the vent to screw into.
bledsoe3 wrote:I have not purchased mine yet, but I'm told the opening has to be 14 1/4 X 14 1/4. I also read that you'll need extra framing on the outside for the trim ring to screw into. Again, all this info I've got from this forum. So it must be correct. At least I hope so cause that's how I did it.Jim
IraRat wrote:You're cool.
bledsoe3 wrote:You're just saying that cause it was you who mentioned the extra framing for the trim to screw into.
IraRat wrote:bledsoe3 wrote:You're just saying that cause it was you who mentioned the extra framing for the trim to screw into.
If I learned anything here, it's that 14 1/4" dimension.
By the way--my cheap $15 Elixir vent (no fan) fits into that same opening.
