Can you apply too much CPES?
Postby les45 » Wed May 02, 2012 1:31 pm
I just finished my third coat on my weekender project and it is going farther than I thought. I have enough for at least one more coat and maybe part of another. Every coat goes on quicker as it soaks in and makes a sheen. Will it hurt anything to go ahead and apply the fourth coat and maybe with what is left after that a fifth coat on all the end grain? I'll be applying a Valspar tractor paint system for my top coats after I fiberglass the edges.
Larry S.
les45
Images: 605
Re: Can you apply too much CPES?
Postby absolutsnwbrdr » Wed May 02, 2012 1:39 pm
I think that once you start getting the sheen, you've pumped as much CPES into the wood grain as possible. Another coat won't hurt, but it is probably just overkill. I'd use what you have left and focus on saturating the endgrain, as that's the most likely part of a piece of plywood to fail anyway.
Zach
Coming Soon...
absolutsnwbrdr
Images: 412
Postby 48Rob » Wed May 02, 2012 6:33 pm
:ok: :ok: :ok:
48Rob
Postby LDK » Wed May 02, 2012 7:16 pm
I saturated the crap out of my endgrain and when I ran out of cpes I started using spar-urethane. My endgrain had
a pretty good buildup. :lol:
LDK
Postby txcamper » Wed May 02, 2012 11:04 pm
Are the fiberglass edges necessary or is fill-it epoxy on the seams and roof to wall joint enough?
txcamper
Images: 129
Postby les45 » Thu May 03, 2012 5:19 am
txcamper wrote:Are the fiberglass edges necessary or is fill-it epoxy on the seams and roof to wall joint enough?
Everything I've read indicates that the fiberglass tape adds strength to the joints and may keep the skins from separating later. I stapled and glued my 1/4" roof panels to cleats along the perimeter of the sides and not directly into the end grain of the 3/4" ply sidewalls. Also, the tape and epoxy covers all the staple and screw holes along those joints. I would think that the amount of work to apply fiberglass tape and epoxy would be about the same as filling every hole and crack with a filler and then sanding and coating til smooth. It may be overkill, but that's what I've tended to do about everything else on my build anyway. With the high cost of CPES, I will definitely use every drop of it to seal as much as possible before I start the fiberglass.
les45
Images: 605
Postby txcamper » Thu May 03, 2012 10:55 am
Thanks for the quick feedback.
txcamper
Images: 129
