parnold wrote:Pressure treated wood has nasty chemicals, that you don't really want being released into the interior of the trailer. If you were to completely seal the wood it would be fine.
parnold wrote:My first trailer was ply and luan, covered in polyester resin, then primed and painted with automotive epoxy primer, and automotive acrylic enamel paint. I'm doing the same thing on trailer number two.
jeff0520 wrote:On the topic of pressure treated wood, I have heard that PT wood goes through quite a bit of shrinkage the first year as well. I've heard that the shrinkage can be quite a problem with something built as tight as a TD must be to be weathertite.
Forrest747 wrote:The question I hjave is what type of camping are u planning. 3 weather or taking it icefishing ala Wolfgang. Strength wise u will be fine. Are u planning any windows. You will have to find a pretty narrow window but I am sure its out there. Can you get the 5x9 thinner? Thinking for the roof. Doable yes
