aggie79 wrote:Our door is 30" wide by 36" tall. If you are building a slouchy or standy you can get away with substantially less door width.
So how big are your doors I'll change the heading as it seems like nobody is interested in this but I'm asking cause I'd like to frame in the bed section of my trailer and have just a cubby hole to clime through
droid_ca wrote: I'm asking this as I'd like to do an enclosed area around my bed area so I can use the top for storage as well as structural bracing ( like bunkbeds with walls on the bottom
mikeschn wrote:droid_ca wrote: I'm asking this as I'd like to do an enclosed area around my bed area so I can use the top for storage as well as structural bracing ( like bunkbeds with walls on the bottom
I didn't respond because I can't visualize this.
mezmo wrote:Hi Droid,
Google Image "Box Bed" and "Cupboard Bed". The top of the
first page on each should have a few pics of them. They were
used in Northern European countries to try and help retain the body
heat of the sleepers, plus built-in furniture gives more usable room
in a room etc..
I'd also do a take on Rob48's suggestion of tracing your body outline.
Sit on the floor cross-legged [Google Image that if you need to be sure
what I mean by "cross-legged".] Then measure from the outside of each
knee and add 4-6in to that. Then measure your sitting height [Sit against
the wall/doorjamb and pencil mark the top of your head against it.] and
then add 4-6in to that. Since the door you want is for entry and egress
from the box/cupboard type bed, the measurements I just described
should give a comfortable and usable door/opening size. Size it to You
this way. Having to contort to get into the box/cupboard bed is pointless.
Also, a common practice/feature of them, [since the sleeping surface was
quite elevated to help keep out of the colder air near the floor], was to
have a bench in front or built in front of the entry side/opening. This
acted as a seat area during the daytime and as a step to get into the
bed at night.
Norm/nezmo
DMcCam wrote:Ours are 33" wide by 36" tall to the top of the curve.
Dave
