8-ft Cubby Question
8-ft Cubby Question
Postby JohnF » Fri Oct 07, 2005 8:09 pm
Will a 10-ft aluminum sheet reach from the front of the Cubby across the top to the hinge point of the galley? If you have a Cubby and would check this I would appreciate it...planning a trip to buy the skins as part of parts gathering prior to starting. Thanks.
JohnF
Images: 5
Postby TonyCooper » Fri Oct 07, 2005 8:20 pm
Plans call for 12' sheets but a 10' length will work.. Mine is roughly 9' from bottom front to hinge at galley.
My Tear Build Site
"No comment"
TonyCooper
Official Pot Stirrer
Images: 35
Postby toypusher » Sat Oct 08, 2005 6:08 am
JOhn,
Tony is right. I have a Cubby (see avatar) and it is 9ft from the front to the galley hinge spar point. Have fun building the Cubby!
toypusher
Images: 324
Postby JohnF » Sat Oct 08, 2005 11:06 am
Thanks Tony and Kerry, that's just what I needed to know.
John at Salida, CO
JohnF
Images: 5
Number of sheets and size?
Postby Rebel » Sat Oct 08, 2005 9:23 pm
I noted Kevin lists 4 sheets at 12' each, but as pointed out in your messages, it seems that, for the cubby, one needs two 8' sheets for the sides, a 10' sheet to the hatch and another 8' to do the hatch cover?
Would this be right? Thanks!
Rebel
Building a Tear for Retirement
Rebel
Re: Number of sheets and sizes
Postby kuffelcreek » Sat Oct 08, 2005 10:01 pm
Rebel:
You are correct. But the supplier I bought from charges you for whole sheets, whether you shear them or not, thus the four 12' sheets. I found uses for most of the scraps, such as the inside walls of the galley, the bottom of the floor hatch, the icebox, etc.
Kevin
kuffelcreek
