Folks, I've got a question that's been eating me since I first heard about heating dilemmas concerning some camping situations. I assume most campers have a fire going. What about a steel pipe in a U-shape under the fire, with flexible tubing going to the camper like dryer tubing? That way the surrounding coals heat the pipe, and a PC fan could push the heat into the camper. You could attach a thermostat to the fan so that it would shut off whenever the temperature desired was reached, and even after the fire has died down, the heat from the coals is still hot enough to give you warmth through the majority of the night.
