aggie79 wrote:This question will get you almost as many different answers as asking what your favorite teardrop design is.
I'm in the "float" camp but used sealant/adhesive around the perimeter and at all openings along with the trim to keep the aluminum attached. The exterior trim was bedded in sealant too. All screw and fastener holes were pre-drilled, sealant was injected into the holes, and then the screws/fasteners were put in place. Here's a few photos:
There is some minor oil-canning in the aluminum in the extreme heat of the summer, but I feel that is better than having the aluminum expand and try to separate from being directly bonded to the plywood.
Take care,
halfdome, Danny wrote:Attaching aluminum with contact cement also acts as a wood sealant.
Camp Inn floats their aluminum but sprays a sealant on the raw plywood first.
Something you might consider before covering up all that raw plywood with aluminum.
Dry rot is not a good thing.
Someone shared this photo with me of a Camp Inn on their rotisserie being sealed.Danny
Steve Frederick wrote:I've never done sides, but for roof skins,(I've done two) I used outdoor carpet adhesive. I spread it with a notched trowel. Working time is short, so plan the job. (Do a dry run)
They say that glue will eventually release it's bond, so plan on trim and other items to really hold the skin.
