KCStudly wrote:Too wide as the A frame starts to narrow. Not enough corner clearance with the TV.
... and the appearance thing, too.
Tho has worked for some.
$.02
KCStudly wrote:On a single tongue frame securing such a wide box to the front of the cabin seems to be mandatory, but, as I have said before elsewhere, I would have a concern about the interaction between the somewhat flexible tongue and the mostly rigid cabin. Wouldn't want the tongue box or cabin to get broken up by the repeated flexing action of the tongue.
working on it wrote:fore-and-aft flex won't rip the Tek screws from the frame.My only concern about this arrangement is that someone may try to stand on the outriggers...I may need to label them "NO STEP". Citylights- you could do something similar, but yours could be totally hidden under the box, just to spread the load.
citylights wrote:working on it wrote:fore-and-aft flex won't rip the Tek screws from the frame.My only concern about this arrangement is that someone may try to stand on the outriggers...I may need to label them "NO STEP". Citylights- you could do something similar, but yours could be totally hidden under the box, just to spread the load.
Dude... If you are worried about stress ripping the screws out or someone stepping on it and bending... Then you are using the wrong materials. The last thing you want is for a weakened structure to fail going down the road!
Don't use screws, use a bolt through clamp, or bolt through the frame. Don't use pot metal side brackets, get some real angle iron or tube steel. You don't have to weld it if you use a good bolt setup. I don't weld, so I get real creative when it comes to bolting. On top of that, I would throw a diamond plate metal or even 3/4 plywood shelf (bolted through at multiple locations across the setup too, just to tie it all together.
When I extended my trailer tongue from 4-foot to 6-feet, I used 3/16-inch thick tube steel, rather than the 1/8 inch thick that came with the trailer. Then I cut the hitch off the old tongue and bolted it in as a trailer cross piece to reinforce the new tongue. Trust me, mine is rock solid.
, you have probably read the data, posted by angib, on materials and tongue strength. The 3" tube far exceeds those others listed in strength. I have no doubts about having no appreciable flex; but just in case, the u-bolt can give a little (never say never can happen). The concern is mainly for some 300lb-er (or even me at 220lbs) jumping up on the angle bars to look at the top of the trailer (for reasons unknown). The force incurred may or may not bend the angle bars, or even rip the perforations. The Teks probably won't give. At the present time, I have no need for a platform at the front, so no diamond plate. If ever I detect looseness or instability from my box, I will indeed use stouter materials, but as I am still aiming for as light a trailer as I can get, and still achieve balance, I'll have to wait to scale it for my final decision. Thanks for your suggestions.Trust me, mine is rock solid.
