Window A/C thru back door.. with slider shelf maybe..
Postby ywhic » Mon Dec 21, 2015 8:22 pm
I am looking at a RV door/hatch with lock.. to fit an window a/c thru.. I found a few that will work..
My trailer is a cargo trailer conversion and the door is 1 1/2" thick and hollow luan.. :o
I don't want to mess with the walls at this point as they just got finished up with insulation, paneling, windows, etc..
I was thinking unused driver side rear cargo door.. its pinned to top/bottom..
I was thinking of doing a slide shelf for the 5000 btu a/c to maybe slide in during travel and out when parked/camping..
What type of sliders to you use?? I am looking at 100lbs models on Amzn for like $20/pair.. and are 22" and fully extendable..
Other suggestions or pics on how to do this?? I don't see many on the web(s)..
Would a set of upright AL angles framed out from floor to top of door frame edge with cross bracing on the inside of the door and then shelf brackets on the AL uprights to support the shelf also.. then 3/4" ply wood for the shelf and what for the actual slide drawer would be good to use??
I am looking at a 24" wide hatch.. so a window a/c has the slide out edges to go out to the edge.. I can then wingnut the them open.. (seen that on here)
Al
2016 WellsCargo FT6121 6x12
ywhic
Re: Window A/C thru back door.. with slider shelf maybe..
Postby tlsallada » Wed Dec 30, 2015 5:00 pm
For the units I have built I used the cheapo drawer slides from my friendly Home Depot which cost about $14.00 for a pair. They have worked out great and slide in/out easily. I used a cargo hatch and frame where the AC unit projects from the camper.
138489
tlsallada
Images: 10
