Fender fix??
Fender fix??
Postby Steve Frederick » Sat Jan 21, 2006 8:14 pm
I just picked up a pair of fenders from eBay. Trouble is, they've been cut..
Who was the one who fixed his fenders that were simmalarly affected?
Did a search on fenders...Do you know how many times we talk fenders?? :?
Blessings, Steve
Adirondacks, Upstate New York
Building Journals
Steve Frederick
Custom Teardrop Builder
Images: 29
Postby Gage » Sat Jan 21, 2006 8:56 pm
Steve, what do they look like? We might as well start up another thread (right here) on how to fix Steve's fenders. :thinking:
Have a good day.
8)
Image Image Image
Gage
Images: 28
Postby norm perkiss » Sat Jan 21, 2006 9:15 pm
Steve,
I found this thread on John's fender repair, is it the one you were looking for?
http://tnttt.com/viewto ... ld&start=0
norm perkiss
Images: 62
Postby Steve Frederick » Sat Jan 21, 2006 10:40 pm
Gage wrote:Steve, what do they look like? We might as well start up another thread (right here) on how to fix Steve's fenders. :thinking:
Have a good day.
8)
I'll snap some pics tomorrow! They're '33 ford repros. I got them for $82...The seller turned out to be a neighbor, a couple of miles away!
Oh!! That thread is the one I was thinking of...Mine are not that bad..I think!!
Thanx!!
Blessings, Steve
Building Journals
Steve Frederick
Images: 29
Postby Gage » Sat Jan 21, 2006 11:56 pm
You know I bet I know which ones your talking about. Are the fenders fiberglass and was it the flange area that is cut/trimmed? If so, maybe some fiberglass work will be in line for repair. With your wood working skills, you could make a cheep mold that the fender could lay in and be clamped in place and then add some cloth and a piece of thin soft alum angle (glassed in) formed to carry the contour of the fender. Am I close?
Have a good day.
8)
Image Image Image
Gage
Images: 28
Postby john » Sun Jan 22, 2006 4:53 pm
Steve,
Yea, those were my fenders. Sounds like you got a better deal than I did. Post some pics.
Gage is right! Wood working, boats; no problem for you!!
'Nuff said.
Build I -- Scenic ---
http://www.flickr.com/photos/8121727@N04/
Goto the Tear Build file
Build II -- Scenic II ---
viewtopic.php?t=29603
Build III -- Scenic Solo---
viewtopic.php?f=50&t=50324
Travel Blog----Now without Political Commentary
http://polifrogblog.blogspot.com/2009/0 ... -2009.html
The Constitution was ratified, not an interpretation thereof...
Penomeli ikibobo
john
john
Images: 261
Postby Steve Frederick » Sun Jan 22, 2006 5:30 pm
Gage, you're right..John you too!
It's sort of De-Ja-Vu!!
I'm thinking along the lines of some 1/8" ply, got lots of scrap, wrapped around the fender like you did, John. And I think I'll steal the other part of your idea..To make a flange for mounting..
Are the holes in the center of the rear portion of the fender for tail-lights?
I just started two frames today, I probably will putter with the repairs here and there, so, progress will be a tad slow. ;)
Thanx Guys!! :thumbsup:
Oh! How would you attack all those holes!!!
Blessings, Steve
Building Journals
Steve Frederick
Images: 29
Postby Steve Frederick » Sun Jan 22, 2006 5:35 pm
Gage, I just re-read your post..How would you 'glass the aluminum to the fender?? Will it hold? It sounds a lot easier than building up a flange.. :thumbsup:
Blessings, Steve
Building Journals
Steve Frederick
Images: 29
Postby Gage » Sun Jan 22, 2006 6:29 pm
Steve Frederick wrote:Gage, I just re-read your post..How would you 'glass the aluminum to the fender?? Will it hold? It sounds a lot easier than building up a flange.. :thumbsup:
I would form it and then incase it in glass cloth. It would be a part of your patch. As for the holes. There's a couple of ways you can go. Glass a thin piece of alum to the underside and then bondo the holes or you could taper both sides of the holes and fill with epoxy. As for the two holes in the center rear of the fenders. Looks like they were for tail lights.
Hope that helped, have a good day.
8)
Image Image Image
Gage
Images: 28
Postby john » Sun Jan 22, 2006 6:53 pm
They are the same thing!!
I had considered glassing in the aluminum form on my repair. The AL would have had to have been attached to the inside of the fender following the contour (real rough on my fenders). Following the outside of the fender with a perminant AL form would have made an attractive finish more difficult and that is where the real work is anyway. With the AL form on the inside, though, makeing the flage would have been a 2 stage process and perhaps weaker. In the end I scraped the idea because i didn't trust the long term effects of heating/cooling on the built in AL and I didn't like the increased difficulties stated above. What really cinched it for me was someone in my thread bringing up wax paper as a release agent. I had no problem lining everything with wax paper and after less than an hour cure time the wax paper pulled right off. No problem.
The only thing I did that made the glass part a two stage process was after removeing the aluminum form and wax paper from the out side of the fender was that I added a single layer of fiberglass over the seam between the original fender and my repair to add strength. I was unable to get to that seam while the AL form was in place. I added this single layer while the repair was still warm.
I look forward to following the choices you make. By the way, it took me 2 or 3 months of piddiling every so often to fix the fenders. On top of that I didn't mount them but a couple of weeks ago.
Penomeli ikibobo
john
john
Images: 261
Postby Steve Frederick » Sun Jan 22, 2006 7:48 pm
John,
Did you use epoxy or polyester resin??
Any trouble mixing epoxy with polyester..I assume the fenders were done in polyester..I have epoxy.
Blessings, Steve
Building Journals
Steve Frederick
Images: 29
Postby john » Sun Jan 22, 2006 8:00 pm
Something else just occured to me. I don't know if it applies to your fenders.
There is something I don't like about mine and I did't notice it untill after fixing them and trying them on for size. They flare away from the sides at the leading edge. This means that while the sides of the tires are flush with the edge of the fender from the trailing edge forward, they at some point become no longer flush with the wheel at the leading edge and the fenders look too wide for the wheel. Looking at it from the front to the rear, though, they look great.
It may be something to consider before you start working on them. I'll try to post pics tomorrow.
Penomeli ikibobo
john
john
Images: 261
Postby john » Sun Jan 22, 2006 8:02 pm
You posted the question while i was writing.
Epoxy. Smelled just like bondo.
Penomeli ikibobo
john
john
Images: 261
Postby Micro469 » Sun Jan 22, 2006 8:24 pm
Steve... Looks like you fenders were used fo exactly the same thing as John's..... :lol:
John
Micro469
Images: 382
Postby goldcoop » Mon Jan 23, 2006 2:55 pm
Steve-
I don't know if this helps, but it is interesting!
http://www.retroteardrop.com/project/build/fender1.php
Coop
goldcoop
Images: 32
Users browsing this forum: Bing [Bot] and 3 guests
