check this out.......simple hatch
Postby seahorse » Wed Feb 08, 2006 8:50 pm
www.richardflake.com/galleyhatch.htm :thumbsup: Maybe a great idea for generic benroy hatch, or someone looking for a simple hatch idea..............Rob
seahorse
Images: 39
Postby gman » Wed Feb 08, 2006 9:01 pm
Looks like a good way to kill the dreaded "springback" monster! :lol:
Junk is something you've kept for years
And throw away three weeks before you need it.
gman
Postby Spadinator » Wed Feb 08, 2006 9:12 pm
That is a cool idea!!!! Should I try it? I'll be installing roof spars this weekend!!!
:R
Never do anything you don't want to explain to the paramedics.
Spadinator
Images: 47
Postby Bandit » Wed Feb 08, 2006 9:31 pm
Great technique! I had been wondering how to easily build my hatch.
Thanks!
First Metal Cut 02/11/06
Complete! (Almost) 08/22/06
Looking for a trip in the SPRING!!!!
Not Up to Testing the Heater!!!
Thanks for all the HELP!!!!
Bandit
Postby seahorse » Wed Feb 08, 2006 9:33 pm
If spars were eliminated except for top and bottom, you could make as many ribs as you wanted with rib pattern.......just remove 3/4'' from bottom and top for extra ribs.
seahorse
Images: 39
Postby derekxcole » Wed Feb 08, 2006 10:55 pm
Spadinator wrote:That is a cool idea!!!! Should I try it? I'll be installing roof spars this weekend!!!
:R
I want to see this done! Do it and show us photos and tell us how easy or hard it is. Seems like a really great plan.
derekxcole
Postby derekxcole » Wed Feb 08, 2006 11:01 pm
I think it might be easier to cut out the hatch before you spar it.
Then spar it and attach it. What do you guys think?
derekxcole
Postby madjack » Wed Feb 08, 2006 11:29 pm
looks to me like not enough sugar for your dime...to my way of thinking building a hatch is not really a problem...use vertical spars and skin...voila your done...having to cut the side in the horizontal plane is just a pain...trace out your rear profile and cut the matching pieces with your jig saw...sand to finish or better yet, make a pattern and finish out with your router...4 vertical spars for a 4 footer 5 for a 5 footer at least 2in wide and you have no springback problems...not the only way to do it but it is what we did and it was simple, relatively quick and painless and it worked for us
