TONGUE BOX WATERPROOF HINGE
Postby Roberto » Fri Mar 10, 2006 10:27 am
I'm trying to build a Tongue Box and want to set it right up against the trailer wall. I can't figure out how to build a hindge that 1. would clear the wall when opened, and 2. be water tight.
Any suggestions?
- - - - Bob
Roberto
Postby Bandit » Fri Mar 10, 2006 10:57 am
You could use the Hurricane Hinge as used on the galley or you can use a stainless steel piano hinge mounted over a strip of inner tube rubber.
First Metal Cut 02/11/06
Complete! (Almost) 08/22/06
Looking for a trip in the SPRING!!!!
Not Up to Testing the Heater!!!
Thanks for all the HELP!!!!
Bandit
Postby Nitetimes » Fri Mar 10, 2006 11:04 am
Or how about one of those nylon hinges like This one
Rich
- Thomas Jefferson -
Nitetimes
7000 Club
7000 Club
Images: 194
Postby fornesto » Fri Mar 10, 2006 11:35 am
You'll have to set the hinge in 2-3" from the trailer to allow it to open all the way, and a hurricane or stainless hinge would work. One fella' used neoprene under the standard hinge to seal it. Or, you could have two small doors that open outward to the sides or a sliding lid. I thought of using a vintage Coke cooler at one point, but settled on a Model A Trunk that I got at a yard sale.
fornesto
Postby Roberto » Fri Mar 10, 2006 12:25 pm
Side Doors - - -huumm! - - I'll have to give that some thought.
thanks,
- - Bob
Roberto
Postby madjack » Fri Mar 10, 2006 2:39 pm
Roberto, goto my WWW site and look at our front box...it has side doors..............................................Jack
Postby goldcoop » Fri Mar 10, 2006 4:25 pm
Nitetimes wrote:Or how about one of those nylon hinges like This one
Roberto-
That's the hinge I used for my tongue box, galley hatch and interior sofa/bed.
Worked great!
Coop
goldcoop
Images: 32
Postby Roberto » Fri Mar 10, 2006 4:37 pm
:D That looks like it will work - - - I'll try it.
Thanks to all, again
Roberto
Postby emiller » Fri Mar 10, 2006 5:14 pm
:thumbsup: McMaster Carr also carries that type of hinge
emiller
Images: 157
