Stick build ?
Stick build ?
Postby North Ga Teardrop 1 » Wed Aug 07, 2024 5:21 pm
On a stick build what studs of wood are you using for the "studs" plywood strips , hardwood, Pine?
North Ga Teardrop 1
Re: Stick build ?
Postby linuxmanxxx » Wed Aug 07, 2024 7:45 pm
If you can get 3/4" foam 1x2 and 1x3 work great as they match the foam thickness.
Sent from my Pixel 8 Pro using Tapatalk
linuxmanxxx
Images: 10
Re: Stick build ?
Postby North Ga Teardrop 1 » Wed Aug 07, 2024 8:03 pm
I get that, but that wasn't my question. What type of wood are people using for the 1x2,1x3's.
North Ga Teardrop 1
Re: Stick build ?
Postby linuxmanxxx » Wed Aug 07, 2024 8:10 pm
I used just plain white pine culled straight dried ones and worked great. Cedar is lighter and rot resistant but never used it myself.
linuxmanxxx
Images: 10
Re: Stick build ?
Postby tony.latham » Wed Aug 07, 2024 9:33 pm
On a stick build ...
I used 1 x 4's once. Joining was a lotta work.
21 joints x 2. If I recall, it took me three days to finish the two structures and have them ready to sheath.
There's a much quicker way to do it.
Using 8' plywood, you can make the wall as long as you want with spline joints.
I can crank two out two skeletons in an afternoon. The other advantage is they give you much more design flexibility.
:thinking:
Re: Stick build ?
Postby Onajourney » Thu Aug 08, 2024 11:17 am
I recommend using 5/4 clear pine found at the big box store and rip them down to actual 1x2" . I started with ripping plain pine 2x4 and found they are way to soft to get a good bite with a screw. The clear 5/4 is a bit more cost but worth it. My build is here https://www.tnttt.com/viewtopic.php?f=50&t=74957&hilit=oraft
Onajourney
Images: 181
