Satining/Sealing Preference
Postby ezbie » Sun Mar 26, 2006 11:18 pm
What does everyone use to seal their wood TD's? I was planning on a marine grade polyurethane. Am I going in the right direction or the wrong?
Ezbie
Dont F*ck with Mr Yuck!!!
ezbie
Images: 42
Postby madjack » Sun Mar 26, 2006 11:46 pm
EZ, we used MinWax ClearSheild an outdoor rated heavey bodied solvent based polyurethane on all exposed wood parts...all other wood got a coat or3 r 4 of Polycryllic a water based polyurethane...many here have used a spar varnish so the marine poly should work well...I would recommend thinning about 10% and spraying 3 or more coats, sanding any surfaces that will show between coats.
Postby ezbie » Mon Mar 27, 2006 12:15 am
The topic subject was that a spelling error or a Freudian Slip satining(staining)/sealing
ezbie
Images: 42
