Windows
Windows
Postby Chris C » Fri Apr 07, 2006 8:53 am
Does anyone know if there is a manufacture currently building crankout windows..........double or triple?
Chris :D
Chris C
Postby cracker39 » Fri Apr 07, 2006 11:52 am
Chris, Those are what I wanted, and I checked with quite a number of sources. Most said I should check with mobile home parts dealers. I did, and everyone said that they were no longer manufactured. I found one dealer who had two old ones, but they were different sizes. I gave up and orderd the one-pane crankouts from Lil Bear (15" x 30" size) for my side windows.
Dale
cracker39
Images: 233
Postby Ken A Hood » Fri Apr 07, 2006 12:20 pm
I found these, only thing is there an Australian company.
Ken A Hood
Images: 42
Postby Mitheral » Fri Apr 07, 2006 1:02 pm
Still made but basically only available in Florida and California and other places you never need turn on the heat.
What you need to search for is jalousie windows.
Here's a couple of Manufacturers I found:
Yale Ogron {PDF}
International Window
Sturdi-Built
Tafco
Most of these people are making windows for walls so they are a bit thick but maybe something could be adapted. The jambs on the vinyl windows would be especially easy to cut down. The mullions on the Yale windows show only 1 7/8" thickness required though the window would stick out from the wall.
Mitheral
Images: 19
Re: Windows
Postby Joanne » Fri Apr 07, 2006 1:04 pm
Chris C wrote:Does anyone know if there is a manufacture currently building crankout windows..........double or triple?
Chris,
I spent quite a while looking for them myself and could not find new ones. I started hunting through the junkyards for old trailers or campers and finally stumbled across one that had 3 good windows. There are still sources for the weatherstripping and mechanisms to refurbish the windows.
It's still a lot easier to order single-pane crank out windows from Grant. :)
Joanne
New! My Camp Cooking Forum
Project Desert Dawg website
Universal Health Care
Joanne
Queen of Cast Iron
Postby sdtripper2 » Fri Apr 07, 2006 1:31 pm
Chris and Joanne
I too have looked for some hope of finding a source for Jalousie Windows =:(
Joanne here is a definition that could be added to your list. :D
Jalousie Windows: A window that opens up by cranking the bottom section out to about a 45 degree angle, allowing ventilation while protecting from light rain. Most RV windows slide up and down or side to side, which could allow rain to get into the RV.
sdtripper2
Search Garoux
Images: 168
Re: Windows
Postby cracker39 » Fri Apr 07, 2006 1:33 pm
Joanne
And I'm happy that I did. The inside of the frame is flush with my 1 1/8" thick wall. I only have to add molding around the frame. The only modification that I want to do is paint the outside raw aluminum frame white to match my door.
Dale
cracker39
Images: 233
Postby sdtripper2 » Fri Apr 07, 2006 1:36 pm
Just found this type of Tear window. Not sure it will do for Chris?
http://tinyurl.com/lmawn
NEW!!, Crank out, Radius Window, White w/ Safety Glass!
(25 1/4"w x 19 1/2"H)
sdtripper2
Search Garoux
Images: 168
Postby cracker39 » Fri Apr 07, 2006 1:38 pm
For adequate ventilation, I ruled out any window that didn't COMPLETELY open to let air in. When I couldn't find the jalousie type, I went to Grant.
Dale
cracker39
Images: 233
Postby Chris C » Fri Apr 07, 2006 1:46 pm
No, Steve, but thanks. I'm really needing the windows I showed in my first post on the subject. I'm looking for a period look for a woodie. Don't want anything that looks modern.
Chris :D
Chris C
Just the hardware
Postby Guy » Fri Apr 07, 2006 2:21 pm
Dear Chris,
A few months (maybe 8) ago I spoke with Grant about getting just the hardware and mechanisms for the jalousie/awning windows. Grant checked with his manufacturers/resources and called me back with an incredibly low price for great hardware. You might want to contact him about the same issue. He is very accommodating and resourceful.
I write this since I am assuming that you may consider making your own frames, and installing safety/double pane glass in them.
Regards,
Guy
Guy
Images: 44
Windows
Postby rooster » Fri Apr 07, 2006 2:21 pm
Chris, I purchased stuff from Singletons RV Salvage in Washington. Here is their e-mail address. [email protected] I know they have a lot of windows, they just may have your jalousie windows.
Jim, :roll:
Beware of what she wishes....especially with that twinkle in her eye and that mischievious smile....you know it's gonna cost....
rooster
Images: 42
Postby halfdome, Danny » Fri Apr 07, 2006 2:32 pm
Chris, Contact Ed of Ed's Cabinets in Seattle he uses that exact window in the tears he manufacturers, 35 @ last count. Ed is a very nice guy and will be happy to talk teardrops with you. 206-243-5033. Good Luck, Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby PaulC » Fri Apr 07, 2006 3:27 pm
Ken A Hood wrote:Image
Chris, I don't think it being Australian is a problem. What with the exchange rate it could work out being quite economical, if you can wait for them to be delivered. If you like I can check prices etc. for you.
Cheers
Paul :thumbsup:
PaulC
3rd Teardrop Club
Images: 36
Re: Windows
Postby rainjer » Fri Apr 07, 2006 3:52 pm
rooster wrote:Chris, I purchased stuff from Singletons RV Salvage in Washington. Here is their e-mail address. [email protected] I know they have a lot of windows, they just may have your jalousie windows.
Jim, :roll:
I was down there last weekend. They have tons of the at kind of window. Find 2 the same is the only problem.
I decided on these. $50 for the pair.
They are 14 X 21. They even where a left & a right & had screens.
rainjer
King Koleman
Images: 11
