doug hodder wrote:Rainjer...there is a really small weatherstripping that is only 3/8" wide and I believe 5/16" uncompressed.
space your door out at the hinge
doug hodder wrote:Rainjer...I'm guessing that you don't have any offset on the hinge between the body and door...the aluminum molding isn't giving you enough room for the seal....here's an idea...get a small strip of like 1/8" aluminum that you can install under the body side of the hinge, like Nitetimes suggests...that will bump out the door enough to give you some space to house the seal...done this also and it helped...any thick material at the hinge side, like weatherstripping will only make the gap at the latch side tougher to deal with...just an idea...Doug
Gadget Man wrote:Rainjer...
No Problem Man,
Your doors look great, but need a little tweeking, just get a thinner weatherstrip, and shim out the hinge. Problem solved.
You may have to shim out the door latch also.
I think this is a pretty common problem, we have all delt with.
Gadget Man
