Houston we have a problem....(Updated)
Postby rainjer » Wed May 17, 2006 9:53 pm
I finished putting my t-molding & seal on my door & now it will not close.... :x
:thinking:
rainjer
King Koleman
Images: 11
Postby Nitetimes » Wed May 17, 2006 10:04 pm
Looks like you'll need to do one of 2 things, use the thinnest seal you can find or space your door out at the hinge. :cry: :thinking: :thinking:
Rich
- Thomas Jefferson -
Nitetimes
7000 Club
7000 Club
Images: 194
Postby doug hodder » Wed May 17, 2006 10:08 pm
Rainjer...there is a really small weatherstripping that is only 3/8" wide and I believe 5/16" uncompressed....I had to use it and space out the interior handle...after a while of being closed the stripping compressed and I could pull out some of the washers that I used for shims on the interior handle...I bought it at an RV supply place, but did see it at Home Depot the other day...black D shaped...it appears that you really have some thick material...just my thoughts...Doug
Postby rainjer » Wed May 17, 2006 10:24 pm
doug hodder wrote:Rainjer...there is a really small weatherstripping that is only 3/8" wide and I believe 5/16" uncompressed.
That is what that is....
That is the first thing I am going to try. I am going to put a pice of L-extrusion behind it.
rainjer
King Koleman
Images: 11
Postby doug hodder » Wed May 17, 2006 10:56 pm
Rainjer...I'm guessing that you don't have any offset on the hinge between the body and door...the aluminum molding isn't giving you enough room for the seal....here's an idea...get a small strip of like 1/8" aluminum that you can install under the body side of the hinge, like Nitetimes suggests...that will bump out the door enough to give you some space to house the seal...done this also and it helped...any thick material at the hinge side, like weatherstripping will only make the gap at the latch side tougher to deal with...just an idea...Doug
Postby fornesto » Thu May 18, 2006 12:00 am
Or, put a shim between the cam and the inside of the door.
fornesto
Postby TomS » Thu May 18, 2006 6:35 am
doug hodder wrote:Rainjer...I'm guessing that you don't have any offset on the hinge between the body and door...the aluminum molding isn't giving you enough room for the seal....here's an idea...get a small strip of like 1/8" aluminum that you can install under the body side of the hinge, like Nitetimes suggests...that will bump out the door enough to give you some space to house the seal...done this also and it helped...any thick material at the hinge side, like weatherstripping will only make the gap at the latch side tougher to deal with...just an idea...Doug
That's exactly what I did.
It's hard to see because I ran a thin bead down the outside of my hinges. But, I've got a 1/8" thick piece of aluminum under the body side of my door hinges.
Tom Swenson
[email protected]
TomS
Postby toypusher » Thu May 18, 2006 7:23 am
I did the same as Tom did and it works great!
toypusher
Images: 324
Postby Todah Tear » Thu May 18, 2006 7:38 am
Rainjer,
Stuck or unstuck, your door looks really good! :)
Todah
Todah Tear
Images: 282
Postby Gadget Man » Thu May 18, 2006 10:17 pm
Rainjer...
No Problem Man,
Your doors look great, but need a little tweeking, just get a thinner weatherstrip, and shim out the hinge. Problem solved.
You may have to shim out the door latch also.
I think this is a pretty common problem, we have all delt with.
Gadget Man
My kids may be smarter than me,
But I know more.
Gadget Man
Images: 23
Postby rainjer » Fri May 19, 2006 6:50 pm
Gadget Man wrote:Rainjer...
No Problem Man,
Gadget Man
I closes now, but I am not happy with it. :thumbdown:
I shimmed the hinge with a 1/8" X 3/4" aluminium flat stock. I also put another 1/8" thick wood shim behind the latch.
It just stick out too far for my liking. As you can see in the bottom picture, the seal had enough pressure on it to bend my metal.
I will go looking for some different seal tomorrow.
It looks like rain all weekend so I probably will not get much done.
rainjer
King Koleman
Images: 11
Postby madjack » Fri May 19, 2006 6:54 pm
Rain, that "sticking out" you are referring to is why we did ours so that the seal was on the inside, giving a close to flush outside apppearance....
madjack 8)
Postby Artificer » Sat May 20, 2006 12:20 am
If you check out McMaster Carr, and look for part number 93685K11 you'll find a foam rubber bulb seal. Your seal is 5/16", so the 3/16" difference might be good enough to not have to shim the hinge. I have also found this seal at Menards in the paint section. Don't know if HD carries it.
Artificer
Images: 16
