alternative to a dropped floorwell
Postby KA » Sat Jun 24, 2006 2:14 am
Hi All of You Planners,
I'm brainstorming again. I've been thinking about how nice a drop floor would be and that got my wheels spinning about some sort of modified lounge chair approach with a fold up tv-type tray instead. If the mattress were split in two pieces lengthwiseand sewn into a hinged covering, a person should be able to design something that could convert from a loungchair position with semi-upright back (comfortable for reading/eating) and raised support under knees. Then when you want to go to sleep, you could lower the position to flat, just like you do with a lounge chair. Hmm. :thinking: This might be more comfortable than just the flat bed position when you want to hang out inside of the trailer.
What do you think?
Kris
p.s. I hope that owning a teardrop will be as much fun as planning one.
KA
Images: 9
Postby madjack » Sat Jun 24, 2006 3:06 am
hey Kris...the planning is a gas but actually building and using is ever so much more fun...keep them ideas a'rollin'....
p.s.....now where did I put that brochure for the Craftmatic bed... :D ;)
Postby rubyede » Sat Jun 24, 2006 10:13 am
Sounds like a good idea. When my sons were young they had some fold out chairs/beds made with the sections of foam in one joined cover. :thumbsup:
rubyede
Postby WhiteRaider » Sat Jun 24, 2006 10:41 am
Kris, I've seen some futon mattresses/frames designed like that. Sounds like a great idea for a teardrop.
WhiteRaider
Postby rmcelroy » Sun Jun 25, 2006 12:38 pm
Chaise lounge chair w/storage underneath?
Nah, way to..........well maybe
Mc
Wheather you think you can or you think you can't, your right.
Henry Ford
rmcelroy
Images: 27
Postby GregB » Mon Jun 26, 2006 11:19 am
Kris,
I've been planning just that for the MiniBago. I have reclined the front wall of the trailer so that I don't have to sit straight up. What I'm planning is two plywood sheets (one for under the thighs, the other for under the lower legs) mounted on a 3/4" frame and joined with a knuckle joint at the knee. The biggest issue I see is needing some clearance to the side so one can grab the knuckle joint and pull it up. I'll build stops in the floor at mid calf level so the joint can be raised higher or lower to change position. This is my concession to sitting in the tear for extended periods of time. Of course the mattresses will have to be split down the middle along with the two "joints" so that my wife can fold her side flat while I sit up and read. The best part is that it only claims about 1" of height to implement.
GB
I'm not dead, yet. I'm feeling better.
GregB
Images: 108
Postby goldcoop » Mon Jun 26, 2006 4:14 pm
Kris-
I did something similar only oriented it width-wise.
We have a sofa-bed arrangement in the back and a table settee in the front.
Our C'tear is larger @ 6'w x 10'l x 5' h.
Check out my gallery pics...
Coop
goldcoop
Images: 32
