rwelp wrote:Thanks Mike,
I actually thought about a true Benroy rear profile for my build. Do you think it would look ok with a rear profile closer to the Benroy than what I have now? It would definitely give me a little more galley space than what I have drawn now. I just don't want too straight of a profile along the top. Do you still think I should tweak the location of the door? I think I will make it a little narrower.
mikeschn wrote:
Rob,
If you have not cut your side profile yet, you can play with it on your graph paper. I've played with a lot of profiles, and as long as it flows, it looks good.
Your door location is fixed already. It should be centered on your dropped floor. Plus or minus a couple inches... it's your choice.
Everything else is flexible.
I would do a Benroy back end for maximum space, and a Lil Diner front end so you have a little storage.
Here's what you need to do.
1) Grab your sketch paper and draw your chassis, along with the floor that you have built so far.
2) Throw on a Benroy rear end, and a Lil Diner front end, and see if you like it.
3) Take a picture of your sketch, and share it with us...![]()
rwelp wrote:Mike,
I can't thank you enough, your help and feedback is invaluable. If I don't screw up and leave this as a woodie, my skirting will be made of solid cherry.
Rob![]()
