sledge wrote:I would make a Patch to cover the crack, at least a couple of inches , then use some good plastic glue, It will hold a lot better with a patch than just putting the glue into the crack, because the bigger the contact surface the better. Just my idea, but I worked as a mechanic for years.
sledge wrote:sounds like you done good............ nowdays it would be hard to beat that price. I hope it all works out for you.
halfdome, Danny wrote:sledge wrote:sounds like you done good............ nowdays it would be hard to beat that price. I hope it all works out for you.
I'm still waiting for my vehicle. After they put 3 gallons of gas in the new tank and my additional 5 gallons they can't get it started. You can hear the fuel pump but the engine is not getting gas. BTW the mechanic broke my 5 month old fuel pump
so they put in a new one on the mechanics bill, not mine. The mechanic at the junk yard broke that one too
. They said he will get dinged $100 off his pay check. This is one of the many reasons it's best to do your own work whenever possible.
I guess I should have taken it to NASSA they have rocket scientists and mechanics there.
Danny
asianflava wrote:Another way to look at it is, if you worked on it yourself and broke the pump, you'd have to pay for that too.
Glad you found a used tank that worked out. All the used tanks I found were out of state, no one would ship a used tank.
