Question, Where do I find the hardware???
Lemme see if I can make myself clear
I'm attempting to build wall mounted vertical pull out pantry shelving
Here's the wall:
Here's the Cabinet Frame (will put a 1/4 inch back on it): The Cabinet is 28" deep
The crown moulding will be cut out and the frame screwed to the ceiling joists and back wall studs.
The Idea here is to utilize the space (via step stool) all the way to the ceiling. Therefore pull out pantry shelving (prolly about 6 pullouts)
Here's the Idea: Only they won't be floor length. Just Wall Pantry above the counter top.
The only thing I've found that will work is 28" full extension drawer slides (100 lb rating which is adequate) which I plan to mount on the top of the pull out rather than the bottom (more stable hanging than riding).
Now the question:
Is anyone aware of and can source a hardware item made specifically for pull out pantry shelving?????
