Cabinet Hardware Source help (sorry its long)
Postby Geron » Tue Dec 15, 2009 9:37 am
Another Project taking me away from PlayMor II TTT rebuild :cry:
Question, Where do I find the hardware???
Lemme see if I can make myself clear :thinking:
I'm attempting to build wall mounted vertical pull out pantry shelving
Here's the wall:
Here's the Cabinet Frame (will put a 1/4 inch back on it): The Cabinet is 28" deep
The crown moulding will be cut out and the frame screwed to the ceiling joists and back wall studs.
The Idea here is to utilize the space (via step stool) all the way to the ceiling. Therefore pull out pantry shelving (prolly about 6 pullouts)
Here's the Idea: Only they won't be floor length. Just Wall Pantry above the counter top.
The only thing I've found that will work is 28" full extension drawer slides (100 lb rating which is adequate) which I plan to mount on the top of the pull out rather than the bottom (more stable hanging than riding).
Now the question:
Is anyone aware of and can source a hardware item made specifically for pull out pantry shelving?????
If it's not broken, you're not trying hard enough.
Geron
Images: 173
Postby alffink » Tue Dec 15, 2009 9:41 am
Have not checked thier cataloge, but Rockler, usually has most of what you could ever need for cabinets
alffink
Images: 37
Pantry
Postby john curtis » Tue Dec 15, 2009 9:45 am
A good place to try might be Lee Valley tool.When we were in the store the last time the girlfriend went nuts over their kitchen add-ons and the pantry units.Good luck in your search
John
john curtis
Images: 141
Postby Geron » Tue Dec 15, 2009 10:41 am
alffink wrote:Have not checked thier cataloge, but Rockler, usually has most of what you could ever need for cabinets
Thanks Al, Rockler has them. None are 28" in length. Prices are from $100 to 350$ per set. Outa my price range if I use 6 sets.
Guess I'll have to resort to my "signature" line. :roll:
Geron
Images: 173
Postby Creamcracker » Tue Dec 15, 2009 10:50 am
So are you looking for these: Philip
http://cgi.ebay.com/28-Full-Extension-B ... 45ecfa2186
Creamcracker
Teardrop Graduate
Images: 142
Postby Geron » Tue Dec 15, 2009 11:09 am
Creamcracker wrote:So are you looking for these: Philip
That's an awful good price. Haven't found then for less than $15 per set.
Many thanks. Think I'll investigate his "store."
Geron
Images: 173
Postby planovet » Tue Dec 15, 2009 11:10 am
Although I have never built anything like it before, I built a similar pull-out for my tear. Granted it is much smaller than what you plan but I used some standard drawer glides from Lowes and mounted them in the middle.
ImageMark (& Cindi)
planovet
The Cat Man
Postby Geron » Tue Dec 15, 2009 11:28 am
planovet wrote:Although I have never built anything like it before, I built a similar pull-out for my tear. Granted it is much smaller than what you plan but I used some standard drawer glides from Lowes and mounted them in the middle.
That's what I'll have to do only I'll have to top mount mine because I don't plan to have dividers between the pull outs to middle mount the drawer slide on. Also, I'll have "wasted" space at the top where I have to come down below the Crown Moulding. That space can be used for the slides/mounts - If I'm figurin' right :thinking:
Ya'll are helpin' a lot . . Thanks
Geron
Images: 173
