Motorola Droid X users - Look Here
Postby starleen2 » Sat May 07, 2011 11:32 am
Well folks if you own a Motorola Droid X - I have something that is absolutely amazing. The past few Days, I was surfing through some Youtube vids and came across this
Connect a Bluetooth Keyboard to an Android Phone
http://www.youtube.com/watch?v=Aj9qC3oKcZU
So I went out and got an apple wireless Bluetooth keyboard to help me type and take notes on either my phone or tablet . Actually, with a quick search you will find that most bluetooth keyboards will work. I went with Apple because i could get one at a discount. – the app worked like a charm – very easy to pair up and get it working. Then I ran across this:
Real HDMI Android App in Action on the DROID X
http://www.youtube.com/watch?v=eA0bkOy-7n4
While searching, I did find a free app - Xternal Display (free in android market) does the same thing and same concept
So here it is: the whole set up –
Yes – that is a 32 inch display you are seeing!. I’m posting this via the Droid X right now. Now my big ole fingers can use a larger keyboard! My phone and Tablet has just becomes like a fully functional computer - sort of ;) Is this practical - could you use something else - like a netbook and get the same results?
Sure - but the coolness factor just isn't the same
Amazing :thumbsup:
starleen2
5th Teardrop Club
Postby bdosborn » Sat May 07, 2011 12:18 pm
Wow, I bet I could tie that into the DVD player in the trailer and use the phone to stream netflix! :thumbsup: I gotta get me a new phone....
Images: 806
Postby mikeschn » Sat May 07, 2011 1:09 pm
I use the iPhone and an Apple Bluetooth Keyboard, in a similar fashion...
I've never checked to see if I can hang an external monitor on it.
But I now have an Acer Iconia A500 tablet running the Android Honeycomb OS. I'm going to try an pair my apple bluetooth keyboard with it.
But the thing I really want to try using is the HDMI port. Still have to get an HDMI cable though.
Postby mikeschn » Sat May 07, 2011 2:33 pm
Here's what the Iconia A500 looks like... But it's wi-fi only... so I am depending on the campgrounds to have wi-fi. Otherwise I am going to have to learn some of Scott's tricks, using the 3G from the phone.
Postby Jiminsav » Sat May 07, 2011 6:58 pm
well, hot dang..I got a droid x and i need a bigger typer too..might have to find me a bluetooth keyboard.
Jim in Savannah
Jiminsav
Images: 40
Postby Hillmann » Mon May 23, 2011 3:58 pm
Hope you don't mind me changing the subject slightly, but, since several of you know a lot more about phones than I do, I have a question. Can a phone with a data plan be used as internet connection for a computer? To be more specific I want to go with boost mobile and one of there smart phones and there cheapest data plan ($25 a month) and then get rid of internet at home and an work, it would save me about 50 bucks a month, but have heard some say it can't be done others say it can.
Hillmann
Postby starleen2 » Mon May 23, 2011 5:58 pm
The short answer is yes. It depends on the phone and the provider - there are some hacks that allow tethering of a smart phone as a modem. However, be warned! For example, the data rates are being monitored by the cell company. Verizon can tell if a phone is being tethered to a computer via the IP address made the connection - then they will charge you $275.00 early disconnect fee and then shut you off for good. If your data plans allows for it - then go for it - I have unlimited data plan for my phone so I can surf the web with no restriction - the wireless keyboard helps. I also had a blackberry that I tethered to a laptop, computer, and netbook to use as a mobile connection on the road. It's that download times will be limited
starleen2
5th Teardrop Club
Postby Hillmann » Mon May 23, 2011 6:05 pm
Doesn't the unlimited data packages allow tethering? I thought that being unlimited they (the phone company) didn't care what I did with it. I was more or less wondering if it was even possible. I guess I will have to take a closer look and see if boost allows it. Also if it is allowed what is the speed I can expect compared to the 10meg connection I have now?
Hillmann
Postby starleen2 » Mon May 23, 2011 6:15 pm
Hillmann wrote:Doesn't the unlimited data packages allow tethering? I thought that being unlimited they (the phone company) didn't care what I did with it. I was more or less wondering if it was even possible. I guess I will have to take a closer look and see if boost allows it. Also if it is allowed what is the speed I can expect compared to the 10meg connection I have now?
Not always! Be sure to check first. There are many forums that can help you with making the connection - all you need is the phone and the carrier. Check first to see if your phone capable first
starleen2
5th Teardrop Club
