computer problems
Re: thanks
Postby toypusher » Mon Jan 19, 2009 7:23 am
kartvines wrote:Thanks for all the feed back I will work on it for a couple days and maybe it will work, I was told that maybe by installing windows 7 may correct my problems, if not maybe by formatting the entire drive and reinstalling XP will be my next more, at least I can still get to those site on my work laptop for time being. My laptop s running Vista so I am unsure if the setting are the same anyway and if so what setting am I comparing and matching?
If you are running Vista on the laptop then it is most likely running IE 7 and if you update your other computer to IE 7 then you can compare the settings equally.
toypusher
Images: 324
major problem
Postby kartvines » Mon Jan 19, 2009 8:42 am
I went ahead and loaded Explorer 7, then my problems really started, now I am unable to get on line at all, all pages can not be found now
Now I have to take it to the computer store to correct my problem, oh well :( :( :( :(
Image..Image..Image..
Image.
kartvines
Images: 37
Postby iplay10us2 » Mon Jan 19, 2009 9:01 am
You can always use "system restore" to take the computer back to before you installed IE7.
all programs---accessories----system tools----system restore.
Then choose a date before you installed IE7 and follow directions.
And, it is always a good idea to create a restore point before you do any changes (hardware or software) to your computer.
Susann
iplay10us2
Images: 53
Restore
Postby kartvines » Mon Jan 19, 2009 10:01 am
Thanks, I will try that once I get home from work tonight.
Image.
kartvines
Images: 37
Postby rbeemer » Mon Jan 19, 2009 10:41 am
Two things you may want to try.
Turn off your computer,router and modem(if you have one) wait about 30 seconds then turn on the modem and router - let them completely finish booting up, constant green lights, then turn on the computer
If you are connected via wire to your router/modem then try changing out the cord
Rick
If ducks had scales, would fish quack?
rbeemer
thanks
Postby kartvines » Mon Jan 19, 2009 10:44 am
Thank you but I have already done that, many times and I went ahead and bought all new wires to insure they were not posing a problem, but thanks anyway for your fed back
Image.
kartvines
Images: 37
Postby S. Heisley » Tue Jan 20, 2009 12:10 am
Hi, kartvines:
When I first installed IE7, it wouldn't work for me. I called my internet provider and they told me their system was not yet totally functional with IE7 and they told me how to uninstall it. If I remember correctly, I simply deleted it from the programs delete section provided in the "start" menu and then turned off (powered down) the computer. When I restarted, the old version came up. Check with your internet provider's technical support unit. They'll tell you if this is the problem; and also, they can tell you the best way to get back to the previous version, if that's what you need to do.
Another time, when I had problems with only some screens, I found that my software security package had reset some of my Advanced Internet Option settings. It had banned the use of Java Scripts and other such programs. I had go through Tools/Internet Options/Advanced tab and select what was to be allowed. It's hard to say because only you can see what is happening but, I think this may be what you need to do.
Hope this helps.
Postby Mike B » Tue Jan 20, 2009 4:25 pm
You know, you guys are wasting thousands and thousands of words on problems that exist in an operating system that you pay dearly for the privilege of using, when you could be using Linux, which is free and where these problems do not exist.
I just don't understand why. This is a case of "Doctor, it hurts when I do this." The solution is, DON'T DO IT.
Mike
Hayden Lake, ID
Mike
Hayden Lake, ID
Mike B
Postby George Kraus » Tue Jan 20, 2009 5:11 pm
Kartvines
What type of internet connection do you have and is your computer networked with any other?
George
Started on the long road to happiness
George Kraus
Images: 16
Postby Nitetimes » Tue Jan 20, 2009 5:41 pm
Mike B wrote:You know, you guys are wasting thousands and thousands of words on problems that exist in an operating system that you pay dearly for the privilege of using, when you could be using Linux, which is free and where these problems do not exist.
Mike
Hayden Lake, ID
How come everybody says that?? Linux has it's problems too, may not be as many but they are there. Not the least of which is compatibility...... if they could get it to work with stuff people actually use/want and make it a little more user friendly it would be a lot more popular.
Until it will accept the .exe extension it will never take it's deserved role in the mainstream which is a shame because it is a good system. Of course if it worked with .exe files it would have the usual problems. :roll:
I've tried it. I liked it but I don't care for it. I do like the free part.
Of course Windows is real inexpensive if you know where to get it. 8) 8)
Rich
- Thomas Jefferson -
Nitetimes
7000 Club
7000 Club
Images: 194
Postby Micro469 » Tue Jan 20, 2009 10:26 pm
S. Heisley wrote:Hi, kartvines:
Hope this helps.
To get a CLEAN uninstall, allways go to Start-Settings-Control Panel-Add And Remove Programs.... ;)
John
Micro469
Images: 382
Postby iplay10us2 » Tue Jan 20, 2009 10:58 pm
Well, to get a true "clean uninstall" you would really need to be able to go into the registry and edit, but that is for more experienced users. I prefer doing a system restore to an earlier date because that usually takes care of any registry problems.
Susann
iplay10us2
Images: 53
Postby S. Heisley » Wed Jan 21, 2009 1:32 am
Kartvine:
Try calling your internet provider again and see if you can talk to a really good techy person. You might luck out with some good advice. Sometimes you get a newbe; sometimes, not.
If you're going to do a system restore, please be certain that you have a current back-up for your files first, especially your personal files (My Documents, pictures, etc.) or you could loose some things. A system restore only restores the system programs, not your personal files.
...Been there, done that. Computer problems can be a real pain. :(
Good Luck! :worship:
PS. To delete just the one set/grouping of programs(eg. to delete iexplorer 7 & restart to bring back 6), John has it right:
_________________
John
[/quote]
Postby toypusher » Wed Jan 21, 2009 6:53 am
Hope this helps.
Always use the uninstall that comes with the program and IF it does not have one, then use add/remove from the control Panel.
toypusher
Images: 324
Postby Micro469 » Sat Jan 24, 2009 2:56 pm
Is it fixed yet???? :thinking:
John
Micro469
Images: 382
