Aluminum Tear Interiors ?
Postby ALAN GEDDES » Mon Aug 28, 2006 10:12 pm
I have only seen 3 all aluminum tears and none had finished interiors. Were they origionally insulated or paneled ? Am contemplating a scratch built one at home with a pop riveted construction.
Alan
ALAN GEDDES
Images: 34
Postby robfisher » Tue Aug 29, 2006 8:06 pm
Alan, Hello from Idaho. The Tourette had no insulation at all and the only wood was a closet door at the front, a small door on a shelf near your feet and a small cupboard door in the galley. They also had a plywood floor covered in linoleum and some small frames holding screens over the inside of the window openings. And no windows, just a metal flap that sorta sealed on the screen frame. That's it. The rest is just aluminum skin on an aluminum framework all riveted together.
Incidently, the no insulation thing is a real problem in the hot sun or cold nights. When you touch it it can be quite the experience. Everything from third degree burns to frozen skin cells.
Rob Fisher
robfisher
Postby mikeschn » Tue Aug 29, 2006 8:19 pm
Check out Brian's Modernistic here... You can see there is no interior to speak of...
http://www.fototime.com/ftweb/bin/ft.dl ... es?userid={5C07D715-2C4F-40D1-B3A1-32F56DEFC000}&inv=EED356827F3E502&userid={5C07D715-2C4F-40D1-B3A1-32F56DEFC000}&AlbumId={BADF26B8-EE7C-4415-949E-4A2BBD8CC27A}&inv=EED356827F3E502&GroupId={E16BA42D-9475-4CBC-9DF7-97A737CFFBFF}
