Need HELP
Need HELP
Postby Lynne » Tue Oct 17, 2006 11:16 am
This has nothing to do with building a tear drop camper but I thought you guys would be able to help me out a little. I made a screen door with horses running across it and the corners have a fancy piece attached to them. I am having trouble with the 1/4 inchg plywood warping. What I was wondering, would baltic birch work without warping or will I have to go to a thicker piece of plywood.
I don't know how to post a picture of the door I would show you what I have.
Lynne
Postby madjack » Tue Oct 17, 2006 11:35 am
...I would think with horses running across it, that it would get torn up fairly quickly... :D ;) ............ 8)
p.s. a little more info would be nice but 1/4" ply is not usually stable unless some additional framing/stiffening is added...MJ
Postby Jim Marshall » Tue Oct 17, 2006 1:02 pm
Lynne, is it the horses that you cut out that is warping, or the corner pieces?
I started out with nothing and I still got plenty left.
VOL-N-TEAR
Jim Marshall
Images: 63
Postby Lynne » Tue Oct 17, 2006 1:22 pm
Jim, It's the horses I cut out. I am putting a piece behind these to look like a fence but would like to not have it in the next door.
Madjack, the horses are scroll sawn out and fit across the bottom section of the door. The Door Clara seen used what looked like 1/4" plywood.
Lynne
Postby Miriam C. » Tue Oct 17, 2006 1:40 pm
Lynn
How big are the horses? Can you use a piece of 1/4 board instead. May warp less and give a smoother finish. We can get Oak, Poplar and Pine here.
Postby surveytech » Tue Oct 17, 2006 1:44 pm
coat the pieces in epoxy?
would keep the moisture out of it.
surveytech
Images: 6
Postby Jim Marshall » Tue Oct 17, 2006 3:45 pm
Lynne, I would do like surveytech suggested. I like the idea of a fence behind the horses, it will add to the beauty and give the support for the PW not to warp. Here is the picture of your door Lynne. I hope you don't mind that I posted it for you.
Jim
VOL-N-TEAR
Jim Marshall
Images: 63
Postby Lynne » Tue Oct 17, 2006 4:13 pm
No I don't mind you posting the picture Jim. I'm glad you did. It's going to be fun getting the fence behind the horses but it can and will be done or I will be in BIG trouble. I know what to do for the next door now. Clara only wants two more. Thats all. LOL
Lynne
Postby Nytewyng » Tue Oct 17, 2006 5:12 pm
Nice door :applause:
Rob and Deb Mangano
Nytewyng
Images: 30
Postby Lynne » Wed Oct 18, 2006 8:08 am
Rod, Deb, thank you
Lynne
Postby Classic Finn » Fri Oct 20, 2006 1:11 am
Hey that is a very nice door...
Classic Finn
Classic Finn
Midnight Sun Voyager
Images: 146
Postby s4son » Fri Oct 20, 2006 10:35 pm
That is very cool. :thumbsup:
Scott F.
Are we there yet?
s4son
Images: 180
Postby Lynne » Sun Oct 22, 2006 5:04 am
Thank you all.
Lynne
Users browsing this forum: Bing [Bot] and 1 guest
