More radio questions...a challenge...
Postby 48Rob » Mon Mar 02, 2009 7:09 pm
Okay...I'll admit, I was so happy about getting the radio installed on the bike that I forgot about the rest of the time I'll be riding with my helmet...
I have a set of helmet speakers (in my helmet).
What I want to be able to do is plug my helmet into the "new" radio and be able to use it instead of the little battery powered pocket radio I've been using.
Of course I want it to kill the handlebar mounted speakers, just like a home stereo does when you plug in the headphones.
How do I accomplish this?
Rob
48Rob
Postby ERV » Mon Mar 02, 2009 9:00 pm
Not sure but you might be able to hook them to a two way switch. Turn it one way it runs the main speakers the other your head phones. Radio shack might have something. Erv
ERV & JAN
Medina, Ohio
ERV
Images: 90
Postby Greg M » Mon Mar 02, 2009 10:43 pm
Yep, Erv has it. An A/B speaker selector switch is the easiest way to go. Just remember to turn down the volume before you switch to the helmet. :)
-Greg
Greg M
*Geek Extraordinaire
Images: 85
Postby 48Rob » Tue Mar 03, 2009 7:05 am
Thanks! :thumbsup:
Sounds pretty easy...
How is it done in a house stereo?
When you plug in the headphones, it kills the speakers...
Some sort of relay?
Rob
48Rob
Postby madjack » Tue Mar 03, 2009 7:25 am
Rob, the female plug on a home system, has a built in cutout or 2way switch that is mechanicaly activated when the male portion is inserted...I would think a similar setup should be available thru Radio Shack......
p.s. after re-reading, the same setup may be available at your local bunny ranch :o ;) ....................MJ
Postby 48Rob » Tue Mar 03, 2009 10:02 am
Jack,
That's what I was looking for...the "how it works part".
Thanks!
Rob
PS. no bunny ranches around here...but there is a Radio Shack ;)
48Rob
