Adobe Photoshop
Adobe Photoshop
Postby emiller » Sun May 15, 2011 3:10 pm
I have Elements 8 how do you re-size pictures with this program so I can post pictures in my album
emiller
Images: 157
Postby caseydog » Sun May 15, 2011 3:48 pm
I have PS, and Elements is uses the same menus.
Image/Image size is the menu choice.
In the Image size box, set your DPI to 72, then set the pixel width and height to fall within the forum limits.
If your photo is "landscape," just set the width to 820 and the height should be fine.
CD
My build journal is HERE
caseydog
Images: 515
Postby eaglesdare » Sun May 15, 2011 3:50 pm
or go to file>save for web
then change the width to 600 hit apply, then change to jpg, hit ok.
you can then put it in photobucket or i believe you can just upload to your album.
Louella
May the foam be with you.
eaglesdare
Good advice
Postby ssrjim » Sun May 15, 2011 11:11 pm
eaglesdare wrote:or go to file>save for web
Save for web is the best way, that way you don't affect the original file.
93079
ssrjim
Re: Good advice
Postby caseydog » Mon May 16, 2011 2:13 pm
I just do a "save as" after I rezize, and resave as a JPG from the original RAW file.
Another tip: Once you decide what method you want to use, save and "Action" of that method, and from then on, it will be a one-click procedure. "Actions" are incredible time savers.
And... if you have a whole bunch of files to resize, use "File>Scripts>Image Processor." You pick a folder full of pictures to resize, tell it where to save the resized images (choose same folder), and tell it what size limits to apply. It will open all the images, resize them and save them as new files in a new folder within the old folder -- dozens of files resized automatically.
You can use "Image Processor" and have it run an "Action" while it works. So, you could build an "Action that Sharpens, sets the levels, color corrects, or whatever you want done, and "Image Processor" will do it to a whole batch of images automatically.
I am pretty sure Actions and Image processor are in Elements, just as in Photoshop CS.
CD
caseydog
Images: 515
