Portable garages and heat
Postby bg » Sun Apr 16, 2006 7:21 pm
I've been looking at the various 10x20 'garages' (tarp covered).
Specifically item #666201 from www.samsclub.com
Is it going to be bearable/pratical to use this/work under in 100+ degree TX heat?
I'm open for suggestions/different options.
Bobby(, Kim & Wayne)
bg
Re: Portable garages and heat
Postby Larwyn » Sun Apr 16, 2006 7:29 pm
bg wrote:I've been looking at the various 10x20 'garages' (tarp covered).
Just roll up both ends and put a fan or two on one end. It's like working in a hot wind tunnel but then, that's Texas in the summer. Actually mine is set up under trees and well shaded. With the fan it is bearable.
One end of the shelter has doors that are easy to roll up. The other end is a little more work but I use a bungee cord from each corner at the top of the corner poles. I pull the bottom of the oposite corner of the wall to the bungees creating something of a triangle, this triangle is easy for one person to roll up and just tuck the roll behind the bungees.....works for me. :D :D
Larwyn
Larwyn
Mad Kilted Texan
Images: 210
Postby Guest » Sun Apr 16, 2006 7:32 pm
bg,
Just move to Humboldt.
It doesn't get too hot here in the summer. :thumbsup:
Guest
Postby oklahomajewel » Sun Apr 16, 2006 7:59 pm
Thought you were moving way nor'east? I bet their summers are like our springs....
btw... April 16 and hit 95* in OKC... whew! and no wind...
oklahomajewel
Images: 82
Postby bg » Sun Apr 16, 2006 8:27 pm
Larwyn wrote:Just roll up both ends and put a fan or two on one end. It's like working in a hot wind tunnel but then, that's Texas in the summer. Actually mine is set up under trees and well shaded. With the fan it is bearable.
Good to hear from someone that has one of these. If it's doable down in your area then I should certainly be able to do it here. Though I don't have trees to shade the area I want to put it.
Dean wrote:bg,
Almost wish that was as option, but until TX real estate reaches California levels... (or vice versa) I'd never be able to afford it.
oklahomajewel wrote:Thought you were moving way nor'east? I bet their summers are like our springs....
Thought I was too. Then they offered 20% less than the minimum I required (and some other details). I headed home.
Sure was nice up there. Think we broke 100° here today.
bg
Postby vinoscooter » Sun Apr 16, 2006 9:58 pm
Work mournings,or the evening..if possible..drink lots...Water I mean...Fans,misters...Even a run through the sprinkler...Use power tools when ya can..Get helpers, then just sit back & give orders...Gets Hot Hot in eastern WA. also...Trying to paint w/all the bugs was crazy..Had people right behind me w/tweezers picking them out...of the paint...But by all means...Get er Done :)
" You have enemies? Good! It means you've stood up for something at least once in your life."
WINSTON CHURCHILL
vinoscooter
Images: 20
Postby Arne » Sun Apr 16, 2006 10:05 pm
I could not open the link. If it is white, yes, it will be bearable (actually the link opened, but not to a specific item)... if it is a dark color, be prepared to be miserable...... I have a white tarp from sam's that comes with a metal frame, and it quite nice in the summer. White makes a big difference.
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
Postby Gage » Mon Apr 17, 2006 1:08 am
Look at it this way. Do you want to work under the sun or in the shade? Seems like a no brainier to me.
Have a good day.
:thinking:
Image Image Image
Gage
Images: 28
Postby Ira » Mon Apr 17, 2006 7:58 am
Tom Swenson bought one, but I don't know from where. You definitely want to be careful with this and not buy a piece of crap.
Here we go again!
Ira
Forum Storyteller
Images: 118
Postby Larwyn » Mon Apr 17, 2006 12:02 pm
Ira wrote:Tom Swenson bought one, but I don't know from where. You definitely want to be careful with this and not buy a piece of crap.
Good point Ira, I've seen some of these shelters that use only 6 legs and they were probably 1 inch tubing. The one I got from Sam's Club has 8 legs of a much larger diameter tubing, and all 4 walls were included, the side walls even have windows..........
It seems well enough made to hold up for the duration of a TD construction project, even on Tear Drop Time...... :D
Larwyn
Larwyn
Mad Kilted Texan
Images: 210
Postby Sonetpro » Mon Apr 17, 2006 3:56 pm
I have had one up for almost 3 years now. I keep the Jeep in it. It's held up good. But I also live in the woods and it doesn't get direct sunlight.
Sonetpro
Images: 107
Postby Larwyn » Mon Apr 17, 2006 5:44 pm
Sonetpro wrote:I have had one up for almost 3 years now. I keep the Jeep in it. It's held up good. But I also live in the woods and it doesn't get direct sunlight.
And a very fine woods it is at that........ :D :D
By the way Steve do you have those seeds flying in the air right now, the ones that look like little cotton balls..? Just what are they....?
When a good breeze came up yesterday there was so many of them it looked like it was snowing.
Larwyn
Larwyn
Mad Kilted Texan
Images: 210
Postby TomS » Mon Apr 17, 2006 6:27 pm
I got mine for $150 at Ocean State Job Lot in May. It sheltered my TD project until early December. I tore it down when the frame started to buckled due to water accumulating on the roof.
In my view, the shelter was worth it. But, only because I got it dirt cheap. I needed it to last ling enough for me to get my tear completed and it was cheaper and more convient than renting a garage.
Northern Tool has a quanset hut shapped "garage-in-a-box" shelter for $350 that they say is suitable for 4-season use. I've been considering that one as a perminent home for my tear.
Oh yeah, it was veryt hot in there on sunny summer days.
Tom Swenson
[email protected]
TomS
Postby bg » Tue Apr 18, 2006 12:03 am
Thanks everyone for the responses.
Think I may to later in the year to buy something a bit heavier duty that'll last longer, or just wait to build a more permanent garage.
bg
Postby Gage » Tue Apr 18, 2006 12:16 am
I've now got two end to end. The first one lasted for 5 years before I lost the canopy in 60 mph wind gust. I live in the high desert so it is always windy (well most of the time). The replacement canopy only cost me $30 and I expect it'll last just as long. I might just think about taking the canopy down durning our severe wind season. Then maybe it'll last even longer, or I'll have it longer. :lol:
Have a good day.
:thinking:
Image Image Image
Gage
Images: 28
