Do I need a fuse box or in-line fuse?
Anything electric, AC or DC
Postby jasonj » Thu May 30, 2024 7:15 pm
Hello
I have a good idea what I will do for my trailer build: a small weekend travel trailer, about 6' x 8'. I am not going to run 110V wires or outlets. I got a Goal Zero Yeti 400 and solar panel at a yard sale that will be the basis and majority of my electrical system for now. The battery has a 12V DC(?) output and two 120V AC outlets for any small appliances i want to run, so the inverter is taken care of.
I am pulling with a car and have a flat 4 connector for trailer lights, so no charging while driving.
I have attached a diagram at the bottom.
Should I install an inline fuse in the 12V wiring? Or a fuse box? I don't want to disregard safety just out of shear ignorance.
Thank You All
Wiring Diagram.JPG (45.8 KiB) Viewed 749 times
jasonj
Re: Do I need a fuse box or in-line fuse?
Postby tony.latham » Thu May 30, 2024 9:32 pm
The 12 volt line needs to be fused. 14 AWG copper stranded wire (not copper coated aluminum) will work for all of your 12 volt needs. A 10 amp fuse will be fine and you may consider a breaker instead.
That's assuming the 12 volt plug in your Goal Zero is 15 amps or better.
Postby reaver » Thu May 30, 2024 10:45 pm
Honestly, that setup will work well. Ideally, you could charge via solar while driving. That being said, you can run a cable from the 12v output port to a fuse block, and connect all your accessories to that.
Another thing to keep in mind.... Most of the power stations have their 12v output limited to 10-15A
reaver
Images: 6
Postby jasonj » Fri May 31, 2024 12:32 pm
Thank You both
jasonj
Return to Electrical Secrets
