STOP light
Anything electric, AC or DC
STOP light
Postby Mike_La » Mon Jun 08, 2009 7:18 pm
I'm sure I've seen this before through a link in the forum.
I'm looking for a STOP light to use as a (collision avoidance) third brake light. It looks similar to the photo below, but has a bezel(chrome or black) around it, with the word STOP.
Any help would be appreciated.
Thanks,
Mike
Mike
"Believe you can and you're halfway there."
Theodore Roosevelt
Mike_La
Images: 71
Postby shadow8536 » Mon Jun 08, 2009 7:24 pm
Try this.
http://www.lickscycles.com/catalog/prod ... ts_id=1006
It is for a model "A" but it has stop embossed in the lens.
shadow8536
Postby Mike_La » Mon Jun 08, 2009 7:44 pm
shadow8536 wrote:Try this.
Thanks for the link, shadow. Appreciate the quick responce. :thumbsup:
Mike
Theodore Roosevelt
Mike_La
Images: 71
Postby prohandyman » Mon Jun 08, 2009 8:23 pm
Etech
You mean like this
Try looking for a late '30s Chevy truck light
Dan
prohandyman
Images: 785
Postby Mike_La » Mon Jun 08, 2009 8:44 pm
Yes, "Like that".
I'll do a search.
Thanks, Dan..........
Mike
Theodore Roosevelt
Mike_La
Images: 71
Postby wlooper89 » Mon Jun 29, 2009 5:47 pm
For a trailer that has not previously had a third brake light, you may need a logic module. The companies Bargman and Command make them. The module is needed only if the the trailer brake and turn signals are combined, as is the case with my trailer. The logic module powers the third brake light only if both of the brake light/turn signals are on, so the third brake light does not flash with either turn signal. This link explains it better than I can.
http://www.commandelectronics.com/logicmodule.html
Bill
wlooper89
Images: 75
Postby Mike_La » Tue Jun 30, 2009 10:37 pm
Thanks Bill.
My truck is already set up with the Center High Mounted Stop Lamp (CHMSL) power feed wiring.
I'll tap into it.
See PDF below.
http://sysdoc.doors.ch/GM/bull23.pdf
Mike
Mike
Theodore Roosevelt
Mike_La
Images: 71
Return to Electrical Secrets
