Ryobi Battery Hack
Anything electric, AC or DC
Ryobi Battery Hack
Postby MceeD » Tue Mar 02, 2010 11:45 pm
Hello everyone, I wanted to share a little trick I did to help out during my build.
I like many use a set of battery powered tools. Waiting for a battery to charge it a killer.
I hacked a battery and a Tool clip then attached it to a transformer to allow me the ability to use wall power while working in my garage.
It is actually quite simple and the transformer is only about $50 @ Ebay.com
I have done it twice now. My friend needed one too.
Thanks to all for the great resources...
MceeD
Images: 43
Postby eamarquardt » Wed Mar 03, 2010 12:00 pm
Not to quibble but you bought a power supply not a transformer. In your picture the rating of the supply is hidden. How much current can the unit supply?
You can't argue that it works for you. When doing something like this you need to ensure that the voltage and current capabilities of the power supply need to be "close" to what the battery supplied. Under or overvoltage or too little current can damage the motor of the tool.
Good work and thinking "outside of the box".
Cheers,
Gus
eamarquardt
Images: 150
Postby MceeD » Wed Mar 03, 2010 7:28 pm
Quibble away.... It's to much fun to pass up :D
In my job we pretty much call anything that changes electricity a xformer.
This hack actually started by a mistake. I meant to buy a 12vdc one and bought the 24vdc model. I turned the adjustable voltage pot down and got to about 16 or 18vdc ( can't remember exactly) and was think crap what can I use this for... and I saw the 18v battery sitting there.
I have it adjusted to about 19vdc which is a tad lower than a battery at full charge. I have almost built an entire Teardrop at this point. and have not had any signs of damage to any of the tools. I have mostly used the circular saw, for all the plywood ripping and cutting. It can dog a bit if your forcing it through a piece of wood but no more than with a battery.
It is a little hard to read in the picture but it states 100-120v AC/6.5A
MceeD
Images: 43
Quibble!
Postby eamarquardt » Wed Mar 03, 2010 9:53 pm
I love a good quibble! At your work, youse guys (and the fairer sex) probably call a rose a petunia! After all, why expand your vocabulary!
It works!! That's all that is important! You did good checking the voltage and a little low wont hurt and if the drill has enough power you're good to go.
Cheers,
Gus
eamarquardt
Images: 150
Postby Miriam C. » Wed Mar 03, 2010 11:08 pm
:o :thinking: I guess if all you have is battery powered tools this is good! I am thinking a good old fashioned powered tool might be more convenient and cheaper. . .
Postby eamarquardt » Thu Mar 04, 2010 10:09 am
Miriam C. wrote::o :thinking: I guess if all you have is battery powered tools this is good! I am thinking a good old fashioned powered tool might be more convenient and cheaper. . .
What and miss an opportunity to quibble?
Cheers,
Gus
eamarquardt
Images: 150
Postby pete42 » Sun Mar 14, 2010 11:46 pm
I read it as 24 vdc 14.6 amps output
120 vac 6.5 amp
pete42
Postby MceeD » Mon Mar 15, 2010 6:00 pm
pete42 wrote:I read it as 24 vdc 14.6 amps output
120 vac 6.5 amp
You would be correct.
In all the time I have used this contraption the cooling fan has not even turned on, so I'm pretty confident it is way more than necessary. But over kill has it's advantages :-)
MceeD
Images: 43
Postby bve » Mon Mar 15, 2010 8:34 pm
Wouldn't a spare battery be <= $50?
Burke
KISS > COMPLEX
Build threads converted to PDFs.
As of 2008-08-08 I have added more build threads to the pdf collection
bve
Images: 98
Postby MceeD » Mon Mar 15, 2010 10:08 pm
bve wrote:Wouldn't a spare battery be <= $50?
Yeah you got me there :-) Actually I'm down a battery, since I hate to Frankenstein one to make this.
But I had the power supply and I hate waiting for batteries to charge. Eventually I will have all corded power tools for the garage, But untill then this gets me buy and save me some pain and anguish waiting on electrons to store themselves in a medium I can release later..... I want them NOW!!!!
MceeD
Images: 43
Postby synaps3 » Mon Mar 29, 2010 12:02 pm
The good Lithium ones are $99...
The NiCad ones aren't worth anything -- I avoid them.
I've built up quite a bank of "wireless" tools, since I don't have a workshop right now.
I'll probably do this once I have a shop so that I don't have to buy a bunch of corded tools! Being stuck to a battery with no plug nearby sucks. :roll:
-- Dave
Build log: here
synaps3
Images: 254
Return to Electrical Secrets
