Wire size
Anything electric, AC or DC
Wire size
Postby CarlS » Sat Jul 03, 2010 9:52 am
As far as recharging while driving goes, does the wire size matter?
CarlS
Images: 29
Re: Wire size
Postby eamarquardt » Sat Jul 03, 2010 10:33 am
CarlS wrote:As far as recharging while driving goes, does the wire size matter?
Wire size always matters for two reasons:
1) If you push too much current through a wire it will get hot and you can start a fire.
2) If the wire is too small you will lose too much voltage between your source and your load and things won't work correctly. Charging a battery is a bit different as as the battery comes up in voltage, the current will drop, the voltage drop in the wire going to the battery will become less (meaning more voltage will reach the battery), and the battery will still be able to be fully charged. This doesn't happen when a load is fixed and the current/voltage drop remains fixed.
Here is good site: http://www.affordable-solar.com/wire.charts.htm
Cheers,
Gus
eamarquardt
Images: 150
Solar panels
Postby CarlS » Fri Jul 09, 2010 11:54 am
What kind of info can you give me for a solar panel? I was thinking if I'm camping in a sunny area, why not have an inexpensive solar panel out to charge the battery?
CarlS
Images: 29
Postby parnold » Fri Jul 09, 2010 1:12 pm
There are numerous threads about solar panel, and you really need to have some idea of your usage before you can think what size panel to get. For some, a 45watt panel like the Harbor Freight is fine. More tend to go in the 80-90 watt range, and then there are those who go with 200 watt.
parnold
Images: 302
Return to Electrical Secrets
