48Rob wrote:Hi Terry,
Is the battery you found on Amazon a deep cycle battery, or are you using it for another purpose?
It looks like it accepts more charging cycles, and is a "rough duty" battery, but I can't find info on the Amp hour capacity?
Rob
slowcowboy wrote:I think I will skip this tread. the 3/4 ton truck is a problem that can't be gotten around. that kills the recharging from the vechile due to the gas consumption.
the need for lots of battery juice is another killer. camping to me is camping and living in a camper is another.
so I will leave this tread a lone enough said.
slow.
parnold wrote:Slow's truck uses so much gas that it is impractical to charge the battery in the trailer with it. Slow also camps very minimilistic like I do, so lots of battery capacity isn't necessary.
Thank you.
I looked at the page you linked to last night.
I could only find the 200 minute RC rating (reserve capacity).
I searched and searched but could not find a common calculator or formula to turn RC into AH.
I did find some info on another Exide page;
http://www.exide.com/Media/files/Downlo ... Manual.pdf
That shows the XMC-31 as having 100 Amp hours capacity.
The chart is at the bottom of the page.
Looks like a pretty good heavy duty battery that ought to last a long longer than the average deep cell!
Rob
StandUpGuy wrote:You shameless non-minimalist high volume electricity consumer!
OK we will let it go this time but just don't be showing off and running your lights past 11:00.bdosborn wrote:StandUpGuy wrote:You shameless non-minimalist high volume electricity consumer!
But I'm green as I make my own. Right?
bdosborn wrote:Two Deka six volt batteries with 230 amp-hr capacity:
Lots of solar panels:
360 watts worth.
I love electricity and use a lot of it. Last weekend we used 22 amp-hrs on Friday night and 26 amp-hrs on Saturday night. Solar panels had the batteries charged by noon on the following day.
8ball_99 wrote:
Not to get to far off topic since I know the OP is looking at solar to. You said your battery was charged by noon. In real world use about how much power does your 360 watts worth of solar put out?. I know how the internet says to calculate it. Just wondering if you have ever measured the real output on a average day?
