GFCI not working
Re: GFCI not working
Postby burlesot » Sun Jun 02, 2013 7:00 pm
Question one: cuts.... do you mean that I cut into the wires and need to fix those?
Question two: it trips immediately when I have a power cord plugged into the Marinco inlet.
Thanks for your patience and guidance.
Todd
burlesot
Images: 62
Postby bdosborn » Sun Jun 02, 2013 7:14 pm
burlesot wrote:Question one: cuts.... do you mean that I cut into the wires and need to fix those?
Yeah, it looks like you cut the wires when you striped the outer sheath off the cord.
Images: 806
Postby 48Rob » Sun Jun 02, 2013 7:40 pm
Todd,
My post was not meant as an insult, or to be offensive, I am sorry If it came off that way.
The intent was to point out that if you aren't sure how to wire outlets, etc. it is better to get some training before proceeding.
I understand you are just asking for help, all of us do so regularly, but sometimes, when someone asks "how" to do something that should have been covered in the first lesson of a particular trade, it is scary, as jumping in when the person doesn't understand the basics can cause harm.
Rob
48Rob
Postby burlesot » Sun Jun 02, 2013 7:44 pm
Rob,
Really appreciate your response. No offense taken.
I know this is not my forte; was trying to go with the 'super simple AC system' because of that. Ran into some issues with the GCFI system. Not sure what the problem was/is, but appreciate your insight and understand the concern.
Thanks again,
Todd
burlesot
Images: 62
Postby burlesot » Sun Jun 02, 2013 8:09 pm
Rob,
I'll trim the wires again and then let you know if that fixed it.
Thanks,
Todd
burlesot
Images: 62
Postby Dale M. » Sun Jun 02, 2013 10:02 pm
Don't start switching ends.... IF there is no load on "out" side if GFCI when you apply power to "in" side, and there is no bad wiring issues, and GFCI trips, best guess would be GFCI is bad...
Dale
Dale M.
Images: 18
Postby burlesot » Mon Jun 03, 2013 7:50 am
Dale,
Got it.
Will re-do wires and report back, eventually. Last week of school is going to be heinous.
TB
burlesot
Images: 62
Postby H.A. » Wed Jun 05, 2013 4:37 pm
Its unlikely the nicked conductor insulation is the culprit here.
Of course its bad practice to initially nick insulation & worse to just leave it as-is, But if everything is dry,,,Very unlikely its the tripping problem.
Was it already mentioned,,,
Is the power source you are connecting to the Marinco Inlet wired correctly ?
Good luck
H.A.
Postby burlesot » Fri Jun 14, 2013 9:58 pm
Full disclosure: I'm a noodle head.
Turns out it wasn't the GFCI that was faulty. It was me.
The red light doesn't mean that the circuit has been 'tripped' as I thought. It means that the GCFI unit is working properly. I fixed up my wire nicks, and everything worked perfectly. Thanks for your patience.
Todd
burlesot
Images: 62
Postby 48Rob » Sat Jun 15, 2013 5:14 am
Todd,
Glad you figured it out and all is well.
Everyone I know, including me learns the same way; by facing a problem and becoming educated enough to overcome it.
Sometimes the solution is simple, sometimes not.
Every problem solved is another lesson.
Rob
48Rob
Postby burlesot » Sat Jun 15, 2013 8:16 am
Thanks!
burlesot
Images: 62
