Questions about My WFC 8725 Converter
Postby kayakrguy » Wed Dec 13, 2006 1:56 pm
Hi folks,
I have some questions and I hope you can help me with the answers..
First, a fuse question
My WFC converter uses Littel 257 ATO fuses for the outgoing DC lines (3) and the battery circuit (1) In addition there is a fuse to protect against Reverse Battery mis-wiring
The 3 outgoingDC lines and the battery line take a maximum 25A fuse
The Reverse Battery protection fuse is a 30A fuse WHY the difference in fuse sizes? (BTW I intend to fuse my outgoing lines for 15 amps) I cannot understand why the reverse battery fuse isn't much smaller Amp rating than the regular circuits--seems counter-intuitive to me...
My second question is about wiring the unit to the battery. The white wire going to the battery negative is AWG 10. The red wire is AWG 12.
Now, most battery clamps and cables are #'s 2-6--MUCH bigger. So my question is: Do you use 2-6 and connect it to the # 10 & 12 AWG or do you spilce in a length of 10 and 12 to the connectors wire and use those to go to the battery terminals?
Thanks for any help you can offer...
Jim
A disposition to preserve, and an ability to improve, taken together, would be my standard of a statesman...
But what is liberty without wisdom, and without virtue? It is the greatest of all possible evils; for it is folly, vice, and madness, without tuition or restraint.
Edmund Burke
kayakrguy
Images: 195
Postby Greg M » Wed Dec 13, 2006 3:06 pm
Presumably the reverse current protector carries the regular direction current when things are wired up correctly and then ,through a diode, shorts out when hooked up backwards. It would need to be a higher rating than the input fuse so that it doesn't blow before the input does.
As for the wiring; you should probably mount the convertor as close to the battery as possible, and use the existing wires. If you need to mount the convertor further away, I'd only increase the wiring by one size, and that's only if mounting several feet away. A #12 can handle a goodly amount of current.
The most important thing to remember though is to fuse within a foot of the battery for safety. There's nothing worse than having a short before the fuse, where it won't do anything to stop a fire.
-Greg
Greg M
*Geek Extraordinaire
Images: 85
Postby kayakrguy » Wed Dec 13, 2006 11:04 pm
Greg,
Thanks, what you said makes some sense re: the reverse polarity fuse.
As to battery-converter distance. The converter people say that the battery and converter should not be in the same compartment and the converter is not weather tight so should not be where there is moisture...so there will be some distance between the battery and converter. I may put the battery in the hatch, converter in the cabin and run connection through the bulkhead....
What would you suggest for battery (terminal0 clamps if I stay with 10 and 12 AWG to the battery?
Thanks, Jim
Edmund Burke
kayakrguy
Images: 195
Postby bdosborn » Wed Dec 13, 2006 11:48 pm
Jim,
What's the output current of your converter? That's how you pick the wire size.
20A=#12
30A=#10
40A=#8.
Edit: Oops, just reread your post and saw that you have a 25A output fuse. Use #10 wire.
If the distance is less than 6 feet you won't need to worry about voltage drop.
Images: 806
Postby bledsoe3 » Thu Dec 14, 2006 1:29 am
kayakrguy wrote: The converter people say that the battery and converter should not be in the same compartment
Thanks, Jim
My converter did not come with any directions. My battery is mounted next to my battery.
Did they say why they should not be mounted in the same compartment?
bledsoe3
Images: 112
Postby kayakrguy » Thu Dec 14, 2006 8:12 am
Good Morning, Bruce and Greg....working on first cup of Joe...will try to make some sense ;)
First, here's a pic of the converter face plate....
The AC breakers go on the left and the DC fuses go on the right.
Bruce, the warning simply says not to mount in the battery or LP Gas compartment, so battery gassing and Lp leaks and ignition is the reason for the warning.
Greg, the battery is a marine battery, so it has two sets of poles: one set like you see on your car battery and another set, threaded with wing nuts on them. Ideally I would like to have a closed ended connector on the battery but haven't seen any that would crimp on a #12 or #10 wire...but even the lug clamps that are held on with screw tensioners dont have connectors that would crimp on a #10 or #12...?
Bruce, that battery case is neat....it appears to be plastic....with the battery poles on the side? Where'd you get that? Also, your converter is in a case? ditto on question....
Thanks, guys..
Jim
Edmund Burke
kayakrguy
Images: 195
Postby Sonetpro » Thu Dec 14, 2006 8:25 am
Jim, I have the same unit. I used 8 going to the battery. The battery protection fuse is also your main feed when the converter is not powered and you are runniing off the battery. On the circuit feeds fuse them according the the wire that you have on that circuit.
Radio shack should have the right connector for the wire battery connection.
I have a 25 amp feeding a sub fuse panel with all my 5 amp lighting circuits off of that. The others are fused at 10 amp. one going to the stereo. And one going to a 12V power point in the galley.
Sonetpro
Images: 107
Postby kayakrguy » Thu Dec 14, 2006 8:32 am
Greg and Bruce,
I meant to ask another question....the converter people say that the Littel fuse type 257 ATO is the one to use...that's clear.
Now, the reverse polarity circuit is the only one that had a fuse in it when the converter came. It is 30 AMP but is called ATC, not ATO--what is an ATC fuse--how differenct from ATO?
Edmund Burke
kayakrguy
Images: 195
Postby bledsoe3 » Thu Dec 14, 2006 9:22 am
Jim, I assume you meant me and not Bruce. My converter is different than yours so I can't comment on the operation of yours. Here's the front of mine.
It's to the right of the battery box in the other picture. The box was given to me but I think you should be able to find one like at an auto parts store. It is plastic. The top is set to have the cables exit the ends or sides. It also has a strap that mounts to the floor and secures the battery in place. Just cause I already had it, I used 5 awg wire.
bledsoe3
Images: 112
Postby Greg M » Thu Dec 14, 2006 9:40 pm
The difference is between the blade type fuse and the round glass cylinder type. The manual is probably just out of date, so it's nothing to worry about.
On the connector question, you should be able to find a crimp on loop that is a large enough guage at an automotive store. They'll have them for big loads like winches. If that doesn't work try a car stereo installation place.
Good luck
-Greg
kayakrguy wrote:Greg and Bruce,
Greg M
Images: 85
Postby Tripmaker » Fri Dec 15, 2006 10:43 am
Jim
As usual you are one step ahead of me and asked many of the same questions I had. For the circuits I used 14G and 15 amp fuses. I'm just running lights and the Fantastic fan so no big loads planned. I'm using 110 for the coffee pot. I don't know how you are laying out your galley but look at my album and see where I put the same converter you have. I wanted to be able to access the converter and fuses easily if necessary.
I was originally going to put the battery in the lower part of the galley seperate from the converter. However I am reconsidering this because putting the battery in a box it will make it difficult to access and service when necesary. I am also concerned about gas discharge building up. I can put a 3" round vent in that area. Is that enough? My other thought was to locate the battery on the tongue. Greg you make a good point about having a fuse near the battery, I hadn't thought about that. What size wire should I run to the battery with a 10' TD? I have about a 4' run from the converter to the lower galley using the 10 and 12 AWG supplied with the converter. Can I continue that another 12' or so to the tongue? If I go larger do I have to change the wire at the converter? Seems to me there would be no point in have a 8 gauge wire narrowing down to a 12 gauge at the converter as the smaller wire would be the limiting factor. Is that thinking correct?
The other Jim
Jim
Tripmaker
Images: 59
