Geron wrote:Rickxr2 wrote:Question for the electricians. I've never liked connecting a stranded wire to the screw of a 120v recept. Especially with 12ga wire. Too much wire, not enough screw. Will crimp on spade terminals handle the load. It would make a lot cleaner job.
Thanks,
Rick
I certainly hope so. I just mounted two 120vac switches to my porch lights (12vdc) and I crimped on terminals and tightened the screws down on the terminals.
I can't see what harm it could do -- Only breaks the positive wire. BUTTTTT! I'm not speaking from an area of expertise, experience, or acquired knowledge. Maybe someone else can chime in also.
g
Rick
There is a connector or lug rated for the current that you will be using.
Choose the rated lug for the wire and job you are doing.
Crimped connectors or lugs are mechanical connections and must be made correctly.
The most important thing is that you
use the proper tool to crimp the lug.
Use the best crimping tool you can afford that is made to crimp the insulated lugs you have chosen.
Crimped insulated lugs work best with non-tinned stranded wire.
When I get done crimping on the lug, I grab the lug and wire and see if I
can pull it apart with lots of force. If it holds with me pulling it hard, then
most likely it will hold for as long as your rig rolls.
Pretty good read and explanation click-y here
Super Champ crimp tool ... an example of the proper tool to crimp your lugs. (PDF file)
Now if you have to splice or connect wire together ...
this subject has had an extensive thread before.
The opinions are varied to be sure.
Go to this thread if you want to run a gauntlet and lug the conversation even more.
http://tnttt.com/viewtopic.php?t=11935
