Spade termianls
Anything electric, AC or DC
Spade termianls
Postby Rickxr2 » Sat Mar 03, 2007 12:53 pm
Question for the electricians. I've never liked connecting a stranded wire to the screw of a 120v recept. Especially with 12ga wire. Too much wire, not enough screw. Will crimp on spade terminals handle the load. It would make a lot cleaner job.
Thanks,
Rick
Image Image Image
Rickxr2
Images: 125
Re: Spade termianls
Postby Geron » Sat Mar 03, 2007 1:47 pm
Rickxr2 wrote:Question for the electricians. I've never liked connecting a stranded wire to the screw of a 120v recept. Especially with 12ga wire. Too much wire, not enough screw. Will crimp on spade terminals handle the load. It would make a lot cleaner job.
Thanks,
Rick
I certainly hope so. I just mounted two 120vac switches to my porch lights (12vdc) and I crimped on terminals and tightened the screws down on the terminals.
I can't see what harm it could do -- Only breaks the positive wire. BUTTTTT! I'm not speaking from an area of expertise, experience, or acquired knowledge. Maybe someone else can chime in also.
g
If it's not broken, you're not trying hard enough.
Geron
Images: 173
Postby Dale M. » Sat Mar 03, 2007 1:53 pm
120 volt screw connection (standard AC connection) is proven over many many years for solid wire.
For stranded wire (12 volt dc) the options are twist wire and tin it (solder) then wrap it around screw ( similar to solid wire connection), or place spade or ring connector on end of (stranded) wire....
Remember when making wire to scews connection (solid or tinned wire) always make wire into hook shape and it always wrap "hook" around screw in clockwise manner....
Dale
Dale M.
Images: 18
Re: Spade termianls
Postby sdtripper2 » Sat Mar 03, 2007 2:40 pm
Thanks,
Rick
g
Rick
There is a connector or lug rated for the current that you will be using.
Choose the rated lug for the wire and job you are doing.
Crimped connectors or lugs are mechanical connections and must be made correctly.
The most important thing is that you use the proper tool to crimp the lug.
Use the best crimping tool you can afford that is made to crimp the insulated lugs you have chosen.
Crimped insulated lugs work best with non-tinned stranded wire.
When I get done crimping on the lug, I grab the lug and wire and see if I
can pull it apart with lots of force. If it holds with me pulling it hard, then
most likely it will hold for as long as your rig rolls.
Pretty good read and explanation click-y here
Super Champ crimp tool ... an example of the proper tool to crimp your lugs. (PDF file)
Now if you have to splice or connect wire together ...
this subject has had an extensive thread before.
The opinions are varied to be sure.
Go to this thread if you want to run a gauntlet and lug the conversation even more.
http://tnttt.com/viewtopic.php?t=11935
sdtripper2
Search Garoux
Images: 168
Re: Spade termianls
Postby Nitetimes » Sat Mar 03, 2007 2:52 pm
Rickxr2 wrote:Will crimp on spade terminals handle the load.
Thanks,
Rick
The short answer is Yes. :thumbsup:
Rich
- Thomas Jefferson -
Nitetimes
7000 Club
7000 Club
Images: 194
Re: Spade termianls
Postby sdtripper2 » Sat Mar 03, 2007 2:55 pm
Thanks,
Rick
:lol: :lol: :D :lol: :lol:
sdtripper2
Search Garoux
Images: 168
Re: Spade termianls
Postby Geron » Sat Mar 03, 2007 3:21 pm
Thanks,
Rick
I don't understand. Could you explain??
:lol: :lol: :lol: :) :lol: :lol: :lol:
Geron
Images: 173
Postby Nitetimes » Sat Mar 03, 2007 3:42 pm
I see the wiseacres are all present today!
:lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
Rich
Nitetimes
7000 Club
7000 Club
Images: 194
Postby sdtripper2 » Sat Mar 03, 2007 3:58 pm
Nitetimes wrote:I see the wiseacres are all present today!
Rich:
Can't speak for Geron, But~
I was laughing at myself and your cut to the quick ... spot on answer.
Here I had fussed and fidgeted trying to get an answer that wouldn't be
to controversial .... and then you POP uP and just get to the point.
Showing me that all my fussing wasn't needed~
:lol: :lol: :lol: :D :D :lol: :lol: :lol:
sdtripper2
Search Garoux
Images: 168
Postby bledsoe3 » Sat Mar 03, 2007 4:30 pm
We do a fair amount of crimping at work.
Several of our crimpers cost more than $350 each. We do have some 120vac.
bledsoe3
Images: 112
Postby Nitetimes » Sat Mar 03, 2007 4:34 pm
I was just funnin with ya Steve.
You frequently impress me with the stuff you come up with so keep it up!
:thumbsup: :thumbsup:
Guess I'm in one of them moods today.
But sometimes there really is a short answer.
8) :lol: :lol:
Rich
Nitetimes
7000 Club
7000 Club
Images: 194
Postby Nitetimes » Sat Mar 03, 2007 4:35 pm
bledsoe3 wrote:We do a fair amount of crimping at work.
That looks like waaay more fun than I want to have!! :shock: :shock: :shock:
Rich
Nitetimes
7000 Club
7000 Club
Images: 194
Postby Geron » Sat Mar 03, 2007 5:17 pm
Rich:
Speaking for Geron is Geron.
I agree, you never cease to amaze me. I was most grateful for the confirmation of my previous actions.
geron
Geron
Images: 173
Postby bledsoe3 » Sat Mar 03, 2007 5:41 pm
That's just the tip of the iceberg. That is the narrow side of a 3 sided electrical locker. These trains have tens of thousands of connections.
bledsoe3
Images: 112
Postby Rickxr2 » Sat Mar 03, 2007 6:11 pm
Thanks everybody for the input. I think I'll get to some crimping now.
Rick
Image Image Image
Rickxr2
Images: 125
Return to Electrical Secrets
