4123 wrote:Can someone out there in electricland tell me how to make a permanent circuit that drops the voltage from 12 VDC to 9 VDC? I know that radio shack has multiple voltage power supplies etc. but I would like to make one of my own that's simple and only provides the 9 VDC without a bunch of extra stuff. I want to permanently mount it. This will be used to power an amplified TV antenna only. Thanks, Ron
This "buck," or voltage reducing DC/DC converter is designed to power CD players, walkmans, video games, portable TVs, tape recorders, GPS, hand scanners, and radios from automobile cigarette lighter power points.
It is an extremely reliable, full switchmode power supply. These are used extensively as OEM regulating power supplies when 6 to 30 volts is available, and a reduction in voltage is required
wannabefree wrote:Looking at Starleen's schematic - The LM7809 regulator will do the same thing without the resistors. You can probably get one at Rad Shack, or any local elex supply. The circuit is not complete, however. Voltage regulators can be unstable and break out in oscillation if not handled right. To fix that problem you need a 10uF and two 0.1uF capacitors. Put a 0.1uF cap from the input of the regulator to ground, and one from the output to ground. Solder these as close to the regulator pins as you can. Then put the 10uF cap from the input to ground, in parallel with the 0.1. Any doubts, go to www.national.com and look up the 7809, or 317, and they'll tell you how to hook it up.
