Ok, I have my wiring plan (sorry no drawings). I am only doing a 12v system. I am using 10 guage from the battery in the tongue box to the fuse box (located in the cabinet between the cabin and galley). I am using 12 gauge for all the branches. My main issue is that I want to have a 12v outlet in the tongue box for accessories.
Do I run a wire back from the fuse box or can I run a fused wire directly from the battery? I have zero experience with this so I apologize.
How do people run the wires for marker lights? I have a 3/16th thick 2" square tube frame (should be done this week!). My outer wall will cover the frame and I have a 3/4 poplar board between the outer skin and the frame. I am building an 11' profile on an 8ft frame. My thoughts were I can either mount the marker lights ahead of and behind where the frame ends or I can drill through the 1x 4 subframe that rests on the frame. Which one would be better? Thanks.
Ryan
