S*%*T
S*%*T
Postby Reddiver » Sat Apr 23, 2011 6:33 pm
So I hook up the trailer today Brake and Turn lights work running lights dont. Leaving Thursday for the Dam trip. Its in the brown wire I will find it . Glad I hooked up today and not Thursday morning. Damn but I will make the Damn trip
Reddiver
Images: 38
Postby Miriam C. » Sat Apr 23, 2011 6:41 pm
:thumbsup: Hope you find it soon.
Postby Reddiver » Sat Apr 23, 2011 6:44 pm
Thanks I will
Reddiver
Images: 38
Postby starleen2 » Sat Apr 23, 2011 7:46 pm
Gotta hate it when stuff like that happens - Usually it shows up when you are just about to leave . You hitch up the trailer then plug in the light . . .and. . . you find that you have a short somewhere.
starleen2
5th Teardrop Club
Postby parnold » Sat Apr 23, 2011 7:46 pm
I feel for you. I just went through the same thing. Did a lot of unnecessary work trying to track it down. Turned out to be a bad crimp connection. It showed voltage at a meter, or test l.e.d., but when plugged into the trailer, the voltage disappeared.
Good luck!
parnold
Images: 302
Postby Reddiver » Sun Apr 24, 2011 12:16 pm
Ok so with a muti meter when held on white lead on plug and brown lead it buzzes .. So that means that the brown wire must be shorted some where? Fuse gets hot hasnt blown but I am sure it would if left on.
Help I am running out of time :cry:
Reddiver
Images: 38
Postby Yota Bill » Sun Apr 24, 2011 12:37 pm
Reddiver wrote:Ok so with a muti meter when held on white lead on plug and brown lead it buzzes .. So that means that the brown wire must be shorted some where? Fuse gets hot hasnt blown but I am sure it would if left on.
yes, continuity between the brown wire and the white wire means the brown wire is shorted to ground...did you remove the running lights first before making that test? Connected as you stated, the bulbs will complete the circuit and show the brown wire shorted to ground (complete circuit)
Remove all the running lights and test that again. If it is still shorted to ground, start testing further down the circuit, until you find where the short goes away, then the problem is between the last 2 points tested. You could spend a couple hours doing that.
Running a new wire would take about a half hour or so...I would run a new wire, and then fix it correctly after you get back, like rewiring the whole thing.
Yota Bill
Postby Reddiver » Sun Apr 24, 2011 5:31 pm
all lights a led so it is not as easy as unscrewing a bulb.. I think your right running a new Brown. I really suspect it is where it goes through the frame some where Tomorrow I will drop all running lights one at a time. And see what I can find
Reddiver
Images: 38
Postby GuitarPhotog » Sun Apr 24, 2011 8:19 pm
If your lights are LED, they will show conduction (and fairly low resistance) in one direction only.
If your brown to white continuity works with the meter leads in either polarity, you definitely have a short.
Try checking continuity between the frame and the wires and you might find which is shorted to the frame.
<Chas>
GuitarPhotog
Images: 55
Postby Reddiver » Mon Apr 25, 2011 1:43 pm
So I jack it up today plug it in and everything is working.. Let if off the jack and it still working. Now I know the problem is still in there. Do I take a chance and go for it and rewire it when I have more time"? I would have to pull the bumper the running lights and pull the wires through the frame the old wires would work for that... I dont know .
Reddiver
Images: 38
Postby Reddiver » Mon Apr 25, 2011 1:53 pm
Turn and Brake work running lights are on a seperate circuit even if the fuse blows it doesnot shut down turn and brake. If I travel during daylight really wouldnt make a difference.. I am talking myself into it and fixing after the trip when I have plenty of time
Reddiver
Images: 38
Postby bobhenry » Mon Apr 25, 2011 1:57 pm
The fact that is comes and goes could not be a direct short.
Do yourself a big favor and run a temporary ground wire clear back to the tow vehicle if the problem disappears it is simply a weak ground. Remember that brown wire carries the two tails as well as all the clearance lights and this greater load may cause the ground connection to break down.
It has been said on this forum dozens of times "99% of all lite problems are ground related"
Postby Mukilteo » Sun May 22, 2011 9:51 am
Did you find the short?
Eric
Mukilteo
Images: 18
