Dimmer switch
Dimmer switch
Postby Reddiver » Sun May 15, 2011 12:48 am
I would like to dim the lights I put on the hatch.. So where can I get a 12 volt rehostat ? What is the difference in a rehostat and a potentiometer? Would Radio Shack have it the fixture uses tail light bulbs it has two but I can turn one on at a time.. So what do I need
Thank you
Reddiver
Images: 38
Postby eamarquardt » Sun May 15, 2011 12:35 pm
Here is a good explanation of the difference between a pot and a rheostat:
http://www.ehow.com/facts_5859562_diffe ... ostat.html
In short, not that much (just a terminal).
If you have incandescent lights a pot or rheostat will work but the energy lost will be lost as heat. The pot or rheostat will have to be sized to dissipate the heat generated.
A better way is to use a PWM module:
http://encyclopedia2.thefreedictionary.com/PWM
If you have led lights you'll need to use a pwm module. I'm not sure that 12 volt fluorescents can be dimmed.
http://www.eetimes.com/design/power-man ... WM-dimming
PWM modules are available on EBay and aren't that expensive:
http://shop.ebay.com/i.html?_from=R40&_ ... Categories
Hope this helps. Questions?
Gus
eamarquardt
Images: 150
Postby Reddiver » Sun May 15, 2011 2:19 pm
Thanks
Reddiver
Images: 38
Postby john » Thu May 26, 2011 11:38 pm
I used a Camry cluster dimmer (92-96) because they can be bought cheap and it can be easily mounted in a hole on a flat surface.
It has more than two wires but a little fiddling isolated the necessary ones.
Build I -- Scenic ---
http://www.flickr.com/photos/8121727@N04/
Goto the Tear Build file
Build II -- Scenic II ---
viewtopic.php?t=29603
Build III -- Scenic Solo---
viewtopic.php?f=50&t=50324
Travel Blog----Now without Political Commentary
http://polifrogblog.blogspot.com/2009/0 ... -2009.html
The Constitution was ratified, not an interpretation thereof...
Penomeli ikibobo
john
john
Images: 261
