afreegreek wrote:I bought a car charger for my Iphone.. it's a 12v cigarette lighter on one end and a usb port on the other.. no wire, just the plug in part 'cause you use the usb wire that comes with the Iphone.. it was $12.. out of curiosity I tried my LED map light with it and the light worked just fine, then decided to leave it on all night and it was still fine.. I thought that because it was a charger it wouldn't work for anything other than charging a small battery but it looks like that's not the case.. I did this only the one time so doing it a lot might burn it up.. I don't know..
pmowers wrote:I just came across this in a newsletter. It combines 2 15A outlets and 2 USB charging ports. The nice things are that it can just replace an outlet, and the USB ports have covers that snap closed, also turning off the vampire power drain. It looks good for charging cell phones, ipods and the like.
absolutsnwbrdr wrote:Thats pretty nifty if you're plugged in all the time. But it requires a 110v source, and I'll have access to 12V more often than 110v in my teardrop.
