I just got a new tow vehicle, and added a hitch and plug-n-play wiring harness. I had a shop foreman at a Porsche repair shop help me install the hitch and wiring.
I took the TD out for its first journey, and everything works, except the brake lights. The lights work, the turn signals work, and the emergency flashers work.
I used a circuit test light to check the harness on the car side, and that tests out perfectly. So, I plugged the trailer into the outlet on the tow vehicle, and probed the left and right positive wires about a foot past the connection with the test light, with the ground hooked to the trailer frame, and that worked. So, I am getting a current to that point.
When I tried doing the same thing on wires at the back of the trailer, and at one of the tail lights, it did not work.
Somehow, the brake lights are getting power at the front of the trailer, but not at the tail lights, but the tail lights and turn signals work, as do the emergency flashers. And, there is no break or splice between the front and back of my trailer, and it worked perfectly on my previous tow vehicle.
This just does not make any sense to me. What is happening between the first foot of my trailer wiring to the tail lights that would only make the brake lights not work, while BOTH of the turn signals and the emergency flashers work?
HELP?
CD
